Go to Post Do I think the bar is too high? I think impossible dreams and lofty goals are a key part of FIRST; the "top" being extremely far away only pushes people farther. - Chris is me [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 16-11-2011, 09:59
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
Re: Questions about 80/20
Originally Posted by Tetraman View Post
Con: HEAVY AS ELEPHANTS
Big Grin
Remove some of the weight and expense by making your own brackets to use a corners and other fastener locations. The 80/20 folks charge a ton for their simple, thick hunks of aluminum with a few holes drilled into them (the brackets).
