Go to Post So, FIRST is turning into the For the Inspiration of Science and Trains? That makes sense... Not a whole lot of re-branding will be needed.... - dqmot17 [more]
Unread 16-11-2011, 16:53
arthurlockman's Avatar
arthurlockman arthurlockman is offline
Team Captain
FRC #0172 (Northern Force)
arthurlockman is an unknown quantity at this point
Send a message via AIM to arthurlockman
SSH to cRIO
Hi Everyone,
Is it possible to connect to the cRIO through SSH? I know that on the Windows side it has a NetConsole that lets you communicate with the cRIO through the terminal. Can you connect to it in a similar manner with SSH and Terminal (or Prompt on iOS)? If anyone knows how to do that, I would really appreciate the help.
Thanks!
-Arthur
Arthur Lockman
Twitter: @arthurlockman
a.rthr.me
Unread 16-11-2011, 17:20
Re: SSH to cRIO
netconsole sends/receives on UDP port 6666. You just need a program that supports that, such as netcat.
Unread 16-11-2011, 17:24
~Cory~'s Avatar
~Cory~ ~Cory~ is offline
Student
AKA: Cory Rypkema
FRC #0706
~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold~Cory~ is a splendid one to behold
Re: SSH to cRIO
What are you trying to do? FTP and netconsole should be able to handle most tasks...
corin.rypkema.org
WPI Class of '17
'12 Dean's List Finalist, Mentor of 706 - Cyberhawks
Unread 31-01-2012, 18:18
Team Captain
Re: SSH to cRIO
I want to be able to monitor the console without using the netconsole app, essentially.
Arthur Lockman
a.rthr.me
Unread 31-01-2012, 18:54
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: SSH to cRIO
Perhaps if you share your reason for not using the application provided we can suggest possible solutions for your use-case.
Unread 31-01-2012, 20:11
msulaimain's Avatar
msulaimain msulaimain is offline
AKA: Muhammad Sulaiman
FRC #3346 ([{Kamikaze Komets}])
msulaimain can only hope to improve
Send a message via AIM to msulaimain Send a message via Yahoo to msulaimain
Re: SSH to cRIO
FileZilla is always an option if your wanting to transfer files and stuff to your cRio or if you want to transfer a .out file to the ni-rt folder if your handy dandy button in WindRiver isn't uploading code for some reason.
int main()
::::::::: include=>commitment;
::::::::: int=>school name=>Asheboro::High
::::::::: int=>team name=>Kamikaze::Komets;
::::::::: Priority_Queue=>FRC Championship::2012;
::::::::: Max_Element=>Teamwork;
Unread 31-01-2012, 21:51
andreboos andreboos is offline
FRC #3021 (The Agency)
andreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the roughandreboos is a jewel in the rough
Re: SSH to cRIO
I use a modified version of Dustin Spicuzza's cross-platform netconsole:
#!/usr/bin/env python2
import socket
import select
from sys import stdout as stdout
UDP_PORT=6666
sock = socket.socket( socket.AF_INET, socket.SOCK_DGRAM, socket.IPPROTO_UDP )
sock.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
sock.setsockopt(socket.SOL_SOCKET, socket.SO_BROADCAST, 1)
sock.bind( ('',UDP_PORT) )
sock.setblocking(0)
while True:
    result = select.select( [sock], [], [] )
    msg = result[0][0].recv( 8196 )
    for c in msg:
        stdout.write(c)
Unread 07-02-2012, 19:57
Team Captain
Re: SSH to cRIO
My reason? My main computer is a mac. If I didn't have to fire up windows just to watch the netconsole, I'd be happy.
Arthur Lockman
a.rthr.me
Unread 08-02-2012, 00:11
Re: SSH to cRIO
Have you tried netcat or ncb? How about the python above?
Unread 08-02-2012, 10:20
Team Captain
Re: SSH to cRIO
The python seems to work fine for me. Thanks guys.
Arthur Lockman
a.rthr.me
