Go to Post Be yourself and do what you love. - Greg Marra [more]
Unread 14-11-2011, 15:10
ebakan ebakan is offline
FRC #0254
ebakan has a spectacular aura aboutebakan has a spectacular aura aboutebakan has a spectacular aura about
Team 254 2011 FRC Code
Hey all,
I'm Eric Bakan and I'm Team 254's Head of Programming/Controls aka Chief Executive Brogrammer. With the conclusion of our last offseason event, the MadTown Throwdown, Team 254 is releasing our 2011 FRC codebase.
The code can be viewed and downloaded from our team GitHub at https://github.com/Team254/FRC-2011
We had used SVN for the duration of the season but unfortunately our server died and we lost all our SVN backlogs. Based on our programming team's previous experience we've decided to move to Git for our version control, primarily because it allows us to make offline commits when we have intermittent internet access on our developer laptop. At the moment this is merely the snapshot of our code as of the end of Championships.
We hope that releasing this code will prove useful to other teams. The included README should provide useful details about the architecture of the system and the individual files should have further notes.
Our only request is that you leave a reply if you found any of this code helpful. Everything is released under a 2-Clause BSD License so feel free to use any part of it.
Unread 14-11-2011, 15:34
Jared Russell's Avatar
Taking a year (mostly) off
Re: Team 254 2011 FRC Code
Thanks for posting! The attention to detail is astounding. 4 different sets of PID gains for the elevator, depending on direction and number of stages engaged?
EDIT: And that's before I even saw the state space controller for the drive
Unread 14-11-2011, 16:59
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
Incredibly exciting to see such sophisticated robot code being open sourced. I would love to see other teams follow suite
Unread 14-11-2011, 17:02
Thanks! We had a lot of fun this year. Did you also notice the threading and how we implemented Auto mode? We use trapezoidal motion profiles for all the drive commands to generate very smooth motions. We also improved the drive code so that it is even smoother and more responsive than the 2010 code. We learned a lot and will be applying what we learned to next year's code.
Drove the robot forwards for 3 seconds, spun for 3 seconds, modeled the robot from first principles, plugged in the ideal constants, fit the constants to the actual response, designed a controller in Matlab, deployed it to the robot, and it worked first try. Sooo tempting to try it for the other systems next year. I decided to model the drivetrain as MIMO. Previous attempts to model it as SISO were resulting in the bot twitching left and right a bit once it stopped due to the false assumption that accelerating one side did not result in any force on the other side.
If you or anyone else has any questions, we'd be glad to try and answer them.
Unread 14-11-2011, 18:20
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Thanks for posting the code Austin. I'd never heard of trapezoidal motion profiles, but the first Google link seems to give a basic understanding. I haven't been able to view the code yet, but have what assumptions about acceleration/deceleration of the manipulator parts (lift & wrist) were you able to make when modeling their movement?
GitHub
Unread 14-11-2011, 18:48
We used a simple PD loop on the wrist and elevator with some gain scheduling, since it worked well enough after hand tuning. The elevator changes mass when it starts to lift the second stage, so there is a second set of constants for that case. For both the arm and elevator, they would undershoot when approaching the goal from below, and overshoot when approaching the goal from above. To solve this, we have 2 sets of constants, one per direction. This solved our overshoot problems. I also avoid integral whenever possible. We just accepted the small steady state error on the elevator and wrist, and moved on, rather than spending the extra time to tune the integral constant across 6 sets of constants. We pass a goal into the two sub systems when we hit the setpoint buttons. The manual joysticks for those two systems also tweak the goals, rather than doing anything with power.
One thing we realized when driving the robot was that it was very useful for the arm to be angled ~50 degrees above horizontal when lining up to place a tube. To facilitate this, whenever a setpoint button is hit, the elevator raises up, and then when it is all the way up, the arm tilts forwards. When the driver hits another button, the robot then goes through an "auto-score" motion which opens the claw, spits out, lowers the elevator, then raises the arm back up, and backs the robot up. This offloads a lot of stuff from the drivers.
Most of the fancy controls is in the drivetrain, which we spent easily over a month working on to tune the robot so that it was accurate and precise enough to score two tubes.
Unread 14-11-2011, 20:43
rachelholladay's Avatar
rachelholladay rachelholladay is offline
FRC #1912 (Team Combustion)
rachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond reputerachelholladay has a reputation beyond repute
Ah, if only I knew enough C to appreciate it. (LabVIEW team here) I'm sure it would make me wanna tear up a bit..
Carnegie Mellon School of Computer Science Class of 2017
2012 Dean's List Winner, 2011 NWCIT Award of Aspirations in Computing National Winner
2014 - : FIRST Team 3504 Girls of Steel (Mentor)
2014 Engineering Inspiration
2006 - 2013: FIRST Team 1912 Combustion (Webmaster / Controls Capt / Beta Test Lead / Drive Capt / JrFLL Coach)
2013 Woodie Flowers Finalist for Wendy Holladay. 2010 - 2013 Regional Chairman's Award at the Bayou Regional. 2011 - 2012 Best Website at the Bayou Regional. 2010 - 2013 Beta Test Team for Hardware and LabVIEW. 2012 JrFLL State Expo Coordinator.
Unread 14-11-2011, 21:36
Chris is me's Avatar
AKA: Pinecone
With that kind of automation, you can make any robot score quickly and effectively. Put it on a 254 robot and you see why they have a Championship banner.
Unread 14-11-2011, 22:16
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Interresting...
Is there any reason that you didn't run the elevator and arm as a single integrated system, to simplify things like this? We ran our elevator/arm as a single state machine, and part of the state transition handled actions like this (with the data input being a requested state, and the data output being a pair of setpoints), and fed the positions output into a pair of setpoint controllers and anti-death logic.
Kettering Motorsports
Unread 14-11-2011, 22:45
The system evolved from the two separate systems with minimal automation to being connected together, and we never stopped to think about re-architecting. We also wanted to be able to move the elevator or wrist at any point in time manually and have it cancel the action.
Looking back, I really like how easy it was to write auto modes with the multi-threading that we did, and would like to make it that easy to write auto-score functions as well.
Unread 15-11-2011, 08:04
Yes, multithreading can lead to prettier/less verbose auto modes, in my experience. We have been prototyping a trapezoidal motion profile as well, and I really like how smoothly it achieves distance setpoints with sub-inch accuracy. Are you using a trapezoidal profile for turning in place, as well? (I didn't notice it, but haven't gone through line by line - yet)
EDIT: Yes, I see that you did
Unread 15-11-2011, 13:35
JesseK's Avatar
FRC #1885 (ILITE)
I perused the code over lunch and noticed something that confused me. In your ports file you've assigned both the "B" port of an encoder and a limit switch to digital I/O 10. In order to facilitate this, was there a specific order the wires had to go into the DIN for I/O 10?
We rely heavily on limit switches to act as redundant safeties during programming as well as sensor failures, so being able to pair limit switches with encoders in this manner could save us from having to make I/O port tradeoffs.
GitHub
Unread 15-11-2011, 14:31
The port definitions for the top and bottom roller encoders are probably obsolete. It doesn't look like either of those encoders is actually used in the code, so there's no real conflict.
Unread 15-11-2011, 14:33
Correct. There are no encoders on the rollers. That sounds like a very old piece of code that didn't get removed as the code evolved...
Unread 17-11-2011, 11:00
Austin,
Could you or one of your programmers explain the rationale behind the design of your victor_linearize function? You average 5th and 7th order polynomials together, but it isn't obvious why you do this.
Thanks
This question was brought on by this thread: http://www.chiefdelphi.com/forums/sh...02#post1085502
