Go to Post I'm totally hooked on reffing now and will be volunteering in the future because of [Beach Blitz]. - Ali Ahmed [more]
Unread 15-11-2011, 23:16
kinganu123 kinganu123 is offline
FRC #1747
kinganu123 is on a distinguished road
Driver Station not picking up PSoC
So we just got the PSoC FirstTouch 3 and I formatted it with FRC_IO.v2.hex as instructed here. However, when I start up the driver station (v02.27.11.00), it doesn't pick it up. Meaning that the I/O LED doesn't turn green.
Any ideas?
UPDATE
We have nothing hooked up to the PSoC except the eStop Cypress Carrier.
Unread 16-11-2011, 02:21
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: Driver Station not picking up PSoC
You need to make sure that you didn't update the Cypress programmer software. If you did, it upgraded the USB code to a new version from Cypress instead of the custom version that allows the DS to talk to the PSoC. If you did update the Cypress programmer software, uninstall it and the Driver Station update, then reinstall the Driver Station update.
-Joe
Unread 16-11-2011, 07:18
Cypress version check:
  • Driver Station Install = 3.12.0.827 (correct version)
  • Update from Online = 3.12.4 or greater (user did an online update - incorrect)
  • Cypress DVD case = 3.10.0.440 (user installed the Cypress DVD – incorrect)
Start PSoC Programmer, then go to Help -> About PSoC Programmer
Unread 16-11-2011, 15:12
Phalanx's Avatar
Phalanx Phalanx is offline
Formerly Team 1089 (Mercury)
AKA: Michael Reffler
FRC #5431 (Titan Robotics)
Phalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond reputePhalanx has a reputation beyond repute
Another quirk we found was to do the following:
Run the Driver Station.
Unplug the PSOC-3 from USB.
Replug the PSOC-3 back into the USB.
Wait a minute or so.
You should then get a message(s) that drivers are being installed.
The PSOC-3 should then become available, and should work hereafter.
Don't just ask the experts, become one!
Leadership is not about ability. It's about responsibility!
Diagonally Parked in a Parallel Universe. It's okay we do Quantum Physics
Unread 16-11-2011, 19:41
FRC #1747
I uninstalled PSoC Programmer, ran the driver station update, and flashed it with the hex file. I'm still not getting any response. If it helps, the PSoC Programmer says that it is FirstTouch3 version 1.15
Unread 16-11-2011, 20:12
Look in Control Panel -> Administrative Tools -> Services
to see if there is a service running called: CyMiniProg3Service
If it's there, what status is listed?
Unread 17-11-2011, 15:26
FRC #1747
Status is set to Manual and isn't started atm
Unread 17-11-2011, 15:42
If the service isn't running then the device in Device Manager will stay as unconfigured and will not be detected by the Driver Station.
Unread 17-11-2011, 18:48
FRC #1747
Ok, so I turned it to Automatic, started the service, and plugged in the PSoC.
It's still not being picked up by my desktop. However, I did bring the team netbook home, and the driver station is picking it up on there. What is wrong with my computer then?
Unread 17-11-2011, 19:15
Compare the ftk_3_simfw.hex file on the 2 machines and make sure that they are identical.
