Go to Post FIRST *is* about winning, and it has made many of us winners... I am glad to be a part of it. - Andy Baker [more]
Unread 16-11-2011, 22:50
blackflame2996's Avatar
blackflame2996 blackflame2996 is offline
Alumni
AKA: David Donahue
FRC #2996 (Cougars Gone Wired)
blackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to allblackflame2996 is a name known to all
Question Bridge
Our Robot is having communication problems, so we replaced the bridge. now it works, but only if the bridge is completely booted before we turn on the CRIO. If they boot simultaneously, the bridge freezes. Any suggestions?
Unread 16-11-2011, 23:11
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Re: Bridge
What do you mean by "The bridge freezes"?
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 17-11-2011, 05:37
Re: Bridge
Do you just mean that the bridge and cRIO fail to communicate?
Can a laptop browse to the bridge, both wired & wirelessly?
Depending on what's really happening to the bridge and what the symptoms are, there are some simple things you can try to get a better idea of what's wrong, like connecting the cable between the bridge cRIO after they boot, or using the reset button on the cRIO.
Unread 17-11-2011, 08:42
Re: Bridge
When you say "bridge" do you mean the white DAP? Is its switch set for Bridge, AP, or Auto? Normally you should use it in AP mode (unless you're at a competition, where it is set to Bridge mode).
Never put it in Auto mode. While it will often work that way eventually, it usually takes a very long time to figure out what you want it to do after it is powered up.
Unread 17-11-2011, 13:42
Alumni
AKA: David Donahue
Re: Bridge
The bridge mode LED indicator goes from blinking (good) to solid (apparently bad) the laptop never sees the cRIO when this occurs. when we allow the bridge to boot completely before booting the cRIO, however, everything works fine.
Unread 17-11-2011, 18:52
Alumni
AKA: David Donahue
Re: Bridge
Yes, the DAP. We'll try it in AP, it was in bridge. thanks for the suggestion.
