Go to Post So Love your robot, and it will love you. - Not2B [more]
Unread 19-11-2011, 10:53
BRAVESaj25bd8 BRAVESaj25bd8 is offline
Bobby D
AKA: Bobby DeFelice
FRC #0250 (Dynamos)
BRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant future
Re: Physics Quiz
I'll use x,y,z to denote right direction, up direction, out of the page direction respectively, based on your drawing.
Sum of moments about the center of the wheel (z axis) shows that the y component of the friction force is tau/r.
Knowing that the axle is a two force member (cannot translate a moment), the friction force must be in the direction theta away from the x axis pointing up and to the right.
The magnitude of the force can be found by finding the resultant of the friction force from the y component we have already. Thus, the friction force is acting at a magnitude of tau/(rsin(theta)) at an angle theta above the horizontal (pointing up and to the right).
Solid question.
Unread 19-11-2011, 11:00
Re: Physics Quiz
Originally Posted by brndn View Post
F = τ/(rsinθ)
Correct!
...opposite the direction of the wheel turning?
Not clear what you mean by the above. But if you mean that F lies in the plane of the wheel, then no.
Unread 19-11-2011, 11:21
Re: Physics Quiz
Originally Posted by John View Post
the forward friction would be F= tau/r
Correct.
sideways friction = tau/r * cotan(theta)
Correct.
The total magnitude of the total friction force is just
F = sqrt ((tau/r)^2 + (tau/r * cotan(theta))^2)
F = tau/r * sqrt(1+cotan(theta)^2)
Correct so far...
F = tau/r * sqrt(1+cotan(theta)^2) = tau/r * sqrt(1/sin(theta))^2= tau/r * cosec(theta)^2
Oops. You forgot the "sqrt". So the answer is wrong.
The angle from the horizontal is
arctan((tau/r)/(tau/r * cotan(theta))) = arctan (tan(theta)) =theta
Correct. (You have a typo, shown in blue)
This makes sense because the friction force has to act exactly opposite to the tension force, or the wheel won't be in static equilibrium.
Correct!
Unread 19-11-2011, 11:25
Re: Physics Quiz
Correct.
Correct.
Correct. Nicely done.
Unread 19-11-2011, 13:42
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
Re: Physics Quiz
I figured it out in the middle of a driving class (about 11:15, EST) but I didn't have internet access when I got it. I was double counting the tau/r which led to the erroneous assumption about the direction of friction I had before. The friction is what drives the wheel forward, not tau/r.
I got the right answer all by myself, though, after I figured that bit out. I learned a little physics, too.
Name:	physics problem.png
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 19-11-2011, 20:59
James Critchley James Critchley is offline
James Critchley is an unknown quantity at this point
Re: Physics Quiz
The "correct" solution is singular about theta = N*pi and is incomplete.
The puzzle contains enough information to solve this. Anybody... ?
