Go to Post The answer the last 3 years would be any regional that 1114 attends. - Cory [more]
Unread 19-11-2011, 12:37
Physics Quiz 2
This is a continuation of the Physics Quiz posted here yesterday.
The weight of the motor+wheel assembly is W.
The coefficient of static friction between the wheel and floor is mu_s.
How much motor torque "tau_s" is required to start the wheel rotating?
Unread 19-11-2011, 12:59
SavtaKenneth SavtaKenneth is offline
AKA: Yotam Kenneth
FRC #2212
SavtaKenneth will become famous soon enough
Re: Physics Quiz 2
we know that when the system is static the force that the wheel exerts on the surface is F = τ/(rsinθ). The minimum force for the wheel to start spinning is F = τ/(rsinθ) > W*mu_s.
and so we get
tau_s > W*mu_s*r*sinθ
2012-Present Referee
2014 & 2015 Israel Regional Volunteer of The Year Award
2212 alumni
Unread 19-11-2011, 13:07
brndn's Avatar
brndn brndn is offline
AKA: Brandon
brndn is just really nicebrndn is just really nicebrndn is just really nicebrndn is just really nicebrndn is just really nice
Re: Physics Quiz 2
F of friction = μmg which is equal to the F in τ=rFsinθ and mg = W
tau_s = r*mu_s*W*sinθ
But as SavtaKenneth said, it has to be greater than in order to overcome static friction.
Re: Physics Quiz 2
and so we get
Correct. Now look at Quiz 3.
Unread 19-11-2011, 13:19
Re: Physics Quiz 2
Notice that when θ is small, it takes very little motor torque to break the static friction and start the wheel rotating. Perhaps you can see the analogy to a skid-steer vehicle with a wide trackwidth.
As θ increases toward 90 degrees, the required motor torque steadily increases. Think of a skid-steer vehicle with a long wheelbase.
Unread 19-11-2011, 21:17
James Critchley James Critchley is offline
James Critchley is an unknown quantity at this point
Re: Physics Quiz 2
I like where this is headed.
FYI: In order for the weight to interact with the ground under the wheel and not via a reaction at the "frictionless pivot" (assumed to be a revolute joint) it must instead be a cylindrical joint. Otherwise the normal force is indeterminate (as it can have any pre-load or none at all).
