Just the sight of you makes my vision system go haywire.
Unread 18-11-2011, 17:05
AdamHeard's Avatar
Lead Mentor
Re: pic: Hart District Robotics Swerve Drive Prototype
I'm curious how the p60s will hold up cantilevered that like. We're overly cautious with them though.
The concept and gearing looks sound, can't really comment on the modules at all.
I think you could make the frame a lot easier for you by reducing the number of members by more than half. A lot of time goes into fabrication of such a frame, and also a lot of weight.
It looks like you could do just two main 3x1 rails (one per side), and lesser framing just connecting those. Would save a lot of time and weight. The frame for our Swerve drive is JUST a perimeter of 2x1x1/16".
What most people don't realize is the code is where you really make/break a crab drive. What have you guys accomplished there so far?
We used incremental encoders (s4's) for our steering, but have used MA3's in the past (as have a few other teams). I know other teams have used limitless potentiometers, and rotary hall effect sensors. Expect to pay $30 minimum for anything of quality.
Unread 18-11-2011, 20:21
Aren Siekmeier's Avatar
on walkabout
Also, how are the p60s mounted? It looks like you need to take them apart and reassemble them around the box tube
Unread 19-11-2011, 18:46
Clem1640's Avatar
Clem1640 Clem1640 is offline
Head Mentor
AKA: Clem McKown
FRC #1640 (Sab-BOT-age)
Clem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond repute
We set up steering drive 1:1, so that steering drive angle provides an accurate proxy measurement for pivot driving angle.
We also used chains/sprockets and belts/pulleys to provide our gear reduction. Drawback is no gearshift (yet). On the positive side, we've got no formal gearbox.
1640 has been running pivot drive two years now. We are pretty satisfied with how it works for us.
The very devil is the control software. We spent a lot of quality time on developing this.
Clem McKown
Head Mentor - FRC 1640 & FTC 7314
Chairman - Downingtown Area Robotics
Unread 19-11-2011, 18:56
AdamHeard's Avatar
Lead Mentor
Gearing other than 1:1 doesn't have to sacrifice accuracy nor precision.
Unread 19-11-2011, 19:00
Clem1640's Avatar
Head Mentor
AKA: Clem McKown
1:1 means that absolute angle measured on the steering drive corresponds to the absolute angle of the pivots. Other ratios require some sort of zeroing.
Clem McKown
Unread 19-11-2011, 19:04
AdamHeard's Avatar
Lead Mentor
This is fact (but can be "fixed" pretty trivially). I just wanted to clarify to the uninformed reading that it's not an accuracy/precision issue, but a reference/zero issue.
Unread 19-11-2011, 19:17
Clem1640's Avatar
Head Mentor
AKA: Clem McKown
Agreed.
Clem McKown
Unread 19-11-2011, 20:37
Garret's Avatar
Garret Garret is offline
Standing on the Shoulders of Giants
AKA: Garret Smalley
FRC #0691 (Hart District Robotics)
Garret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond repute
I know someone asked for a picture of the module itself so I have attached one I took at today's meeting. Currently once we mount the encoders we should be running code. We plan on devoting the rest of our time to working on the code.
About running the steering at non 1:1 ratio, we did this because we could get AM parts that were cheap and were the right size for our shafts. I would run 1:1 but I am designing within my teams constraints.
I forgot to answer how we were going to measure wheel angle.
We plan on using an incremental encoder to determine our position relative to a zero position that would be set by a touch sensor or an optical sensor that would detect a reset/zero point defined by something along the lines of a reflector on the top of the module.
7 Years of FRC
"You students are at the top of the mountain, at the pinnacle of success, and what is it that you do?
You become the future guides to help others climb the mountain."
Unread 23-11-2011, 08:03
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
reported
Hi!
