Go to Post The purpose of the game rules is not to imagine and categorically list everything you should not do, but to give you guidelines of FIRST's intent and leave it to your developing good judgment to know what's acceptable and what is simply skirting the rules. - Mark McLeod [more]
Unread 19-11-2011, 22:46
Re: Physics Quiz 3
Originally Posted by John View Post
so the total friction force would be ... tau_k/(r*sin(theta))
Yes.
But according to the Coulomb friction model, the total friction force must be mu_k*W.
So that means tau_k must equal mu_k*W*r*sinθ.
So, what happens if the voltage to the motor is increased?
Unread 20-11-2011, 09:28
BRAVESaj25bd8 BRAVESaj25bd8 is offline
Bobby D
AKA: Bobby DeFelice
FRC #0250 (Dynamos)
BRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant futureBRAVESaj25bd8 has a brilliant future
Re: Physics Quiz 3
Yes.
This doesn't sound right to me. The torque applied by the motor should not be changing as theta changes. I think the problem is that in order to find the friction equal to tau_k/(r*sin(theta)), you must assume the wheel is gripping. This does make sense because it is able to rotate and drive around the pivot but is inconsistent. I feel like one of the boundary conditions is actually overconstraining the model.
Unread 20-11-2011, 11:34
Re: Physics Quiz 3
tau_k is the motor torque necessary to be in equilibrium at a given angle theta, given the assumptions in the model (mu_k constant, frictionless pivot, frictionless wheel bearing, no wind resistance, no rolling friction, no friction due to rotation of the wheel about the Z axis).
What the equation is saying is that if you reduce the angle theta, it takes less tau_k to be in equilibrium. If you increase theta, it takes more.
Sustaining equilibrium when theta is very small takes very little torque. In fact, when theta is zero it takes zero torque to sustain equilibrium since the pivot is frictionless and we are ignoring wind resistance, rolling friction, friction in the wheel bearings, and friction due to rotation of the wheel about the Z-axis.
So what happens if you start with the system in equilibrium, and you then increase tau_k to tau_k' ?
Unread 20-11-2011, 13:57
Bobby D
AKA: Bobby DeFelice
FRC #0250 (Dynamos)
Re: Physics Quiz 3
After thinking about it more, the error I made was getting wrapped up in angular motion, thinking that theta was the wheel's angular position about the pivot as the system rotates. What it really represents, though is a constant in this problem, the angle between the wheel's axis of rotation and the pivot arm.
I think that if you increase the torque, nothing will change because the wheel is already slipping. The friction cannot be higher than W*mu so no more torque is able to be useful.
Unread 20-11-2011, 14:03
Re: Physics Quiz 3
If you increase tau_k, the system will no longer be in equilibrium. That means something must change.
Unread 20-11-2011, 15:29
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
Re: Physics Quiz 3
Can normal force increase to balance the increase in tau_k? I don't think that actually makes sense but it seems to be the only variable that can change in this case.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 20-11-2011, 15:53
Re: Physics Quiz 3
No.
If the system is in equilibrium, and then you increase the motor torque that's driving the wheel, what happens?
Think torque=momentOfInertia*angularAcceleration. Then follow the causes and effects as they ripple through the system.
Unread 20-11-2011, 16:00
James Critchley James Critchley is offline
James Critchley is an unknown quantity at this point
Re: Physics Quiz 3
Ninja_Bait: Ether has already answered this question in an earlier post... I think the issue is the notion of supplying a larger torque indefinitely. Perhaps it will help to say it another way?
The system will accelerate to a speed where you are no longer able to supply torque greater than tau_k. Physical systems are power limited and power = torque * angular rate. The system will accelerate to the limits of your power supply or motor torque vs speed curve (which ever comes first). At that point the torque supplied by the motor will again be tau_k and you will have constant speeds.
If you could somehow supply a constant torque independent of speed, the system as modeled would properly accelerate forever. Other effects would eventually dominate and the model would become invalid so this wouldn't actually happen, but you would still want to patent that motor and power supply!
Unread 20-11-2011, 17:00
Ninja_Bait's Avatar
AKA: Jake Potter
Re: Physics Quiz 3
Ah, I see. Thank you.
