Go to Post *When putting grease on anything* "The bigger the glob the better the job." - TheMagicPenguin [more]
Unread 20-11-2011, 20:13
whcirobotics's Avatar
whcirobotics whcirobotics is offline
FRC #1514 (Vikings)
whcirobotics is an unknown quantity at this point
Inverting the motors through software
When we ran the java code the motors were inverted so we tried to change its value to negative in software but it would not let us. We know we can just do it physically on the robot, but it is good to learn how to do it through software. We looked online and we came accross this:
public void setInvertedMotor(RobotDrive.MotorType motor, boolean isInverted)
How do we add that in our code to make the motors negative? Here is our code so far that does the basic drive and starts compressor.
CODE:
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.SimpleRobot;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.Jaguar;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.Compressor;
import edu.wpi.first.wpilibj.Solenoid;
import edu.wpi.first.wpilibj.Gyro;
import edu.wpi.first.wpilibj.Victor;
import edu.wpi.first.wpilibj.DigitalInput;
* The VM is configured to automatically run this class, and to call the
* functions corresponding to each mode, as described in the IterativeRobot
* documentation. If you change the name of this class or the package after
* creating this project, you must also update the manifest file in the resource
* directory.
public class RobotTemplate extends SimpleRobot {
Joystick leftstick = new Joystick(1);
Joystick rightstick = new Joystick(2);
Jaguar rearleft = new Jaguar(10);
Jaguar rearright = new Jaguar(9);
Jaguar frontleft = new Jaguar(8);
Jaguar frontright = new Jaguar(7);
Victor victor = new Victor(4,5);
Compressor compressor = new Compressor(11,5);
RobotDrive drivetrain = new RobotDrive(frontleft,rearleft,frontright,rearright );
public void robotInit()
System.out.println("Initializing robot");
compressor.start();//Start the compressor
public void autonomous(){
System.out.println("Entered the autonomous mode");
for(int i = 0; i < 4; i++){
drivetrain.drive(-0.5, 0);
Timer.delay(1.0);
drivetrain.drive(0.0,0.75);
drivetrain.drive(0.0,0.0);
public void operatorControl(){
System.out.println("Entered the teleop mode");
while(isOperatorControl() && isEnabled()){
drivetrain.arcadeDrive(leftstick, false);
"A team back in training !"
Unread 21-11-2011, 08:42
kinganu123 kinganu123 is offline
FRC #1747
kinganu123 is on a distinguished road
Re: Inverting the motors through software
use drivetrain.setInvertedMotor()
There are some default parameter is auto enters, so u can just edit that to the motor you need inverted
Unread 21-11-2011, 08:57
Jared Russell's Avatar
Jared Russell Jared Russell is online now
Taking a year (mostly) off
Right after this line:
You would add code like this:
drivetrain.setInvertedMotor(RobotDrive.kFrontLeft, true);
drivetrain.setInvertedMotor(RobotDrive.kRearLeft, true);
(or use kFrontRight and kRearRight...just remember to invert both motors on the side!)
