Go to Post Yes, I try to win matches, but you don't want to disrespect opponents......just get on their nerves an awful lot! :D - Josh Goodman [more]
Unread 21-11-2011, 09:54
Sh1ine Sh1ine is offline
FRC #2791
Sh1ine is on a distinguished road
Timing Pulley Stock - Machining Question
We are trying to create custom length timing pulleys. We ordered stock from Stock Drive Products (25 tooth GT2.) We need to cut it to size, face it, and center drill a .500 hole so that we can broach it later. When we put the stock into the lathe only two of the three jaws make contact with the outside of the pulley, the third is in between two teeth. Does anyone have suggestions as to how to cut and face the pulley stock?
Thanks.
Unread 21-11-2011, 10:03
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Timing Pulley Stock - Machining Question
Use a collet.
Unread 21-11-2011, 12:00
kaliken kaliken is offline
294 Old Fart Mentor...
AKA: Ken S
kaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant future
I got a great lesson back in my early career and that is the rule of three. For a gear/pulley to align in a 3-jaw check it requires number of teeth to be divisible by three. this allows an equal number of teeth to be resting on each jaw of the chuck. Otherwise you will run into the problem you are seeing and will have to use a 4-jaw chuck and manually dial it in.
2010 World Champions! Newton Alliance Captain: Many thanks to 67 and 177 for the amazing ride
Unread 21-11-2011, 12:02
Chris is me's Avatar
AKA: Pinecone
Originally Posted by sanddrag View Post
Use a collet.
I'd go with this as well, or a four-jaw chuck.
Unread 21-11-2011, 14:39
AdamHeard's Avatar
Lead Mentor
You can also make a psuedo-collet of sorts to us as an adapter with a 3-jaw.
Get a chunk of aluminum and bore it out to where the Id is just barely larger than the pulley, and size the OD such that the walls are pretty thin.
Clamp this collet in the 3-jaw with the pulleystock inside, and it should work.
We do this on the fly probably 5 times per season for various parts.
Unread 21-11-2011, 15:00
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
If you're a lazy machinist who doesn't want to find a collet or make one, can you just wrap it in a thin layer of tape or a piece of belt?
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 21-11-2011, 15:19
AKA: Pinecone
Honestly with I thought to wrap it in scrap timing belt, because that's a really good way to grip it, but securing it side to side on the pulley stock might be hard
Unread 21-11-2011, 15:36
Ninja_Bait's Avatar
AKA: Jake Potter
Judging from the recently posted engineering flowchart, I believe this is a situation for duct tape?
Unread 21-11-2011, 17:22
AKA: Ken S
I would warn against just tape. If you are going to make a psuedo-collet I would go with Adams approach. We have done things like this before and it works well, though we have used PVC or something we can compress against
My reasoning is that you need a surface that you can bear against such that the part does not slip inside the chuck. Tape IMHO may not provide enough rigidity.
Unread 22-11-2011, 00:10
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
We've previously done this, but with a thicker wall. We then bandsaw a slit into the side of it so it can fully collapse.
You're introducing some runout when you do this, but we generally only did this when we wanted to face hubs off of sprockets or gears, where runout didn't matter.
2001-2004: Team 100
2006-Present: Team 254
Unread 26-11-2011, 10:54
DonRotolo's Avatar
Back to humble
FRC #0832
Neither would be acceptable from a safety or accuracy standpoint. They simply cannot grip the workpiece well enough.
Another idea for a collet of sorts, assuming a 4-jaw is not available, is a band of metal about 3/32" thick, bent into most of a circle the size of the workpiece. The ends are left unconnected and separated by a distance about 1/6 of the circumference. You grip at all three jaw locations onto solid metal, which can contract to grip the workpiece. The metal is thick enough to not distort from the clamping forces, and since it rides on the teeth it will maintain concentricity.
For facing it's not important, but for boring the center hole it is.
Ah, yes: Don't "drill" the center hole, bore it with a boring tool, since a drill will wander and make an off-center hole, almost guaranteed.
Unread 11-12-2011, 21:14
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
You could use a mill and make soft jaws for a vice. Band saw to length and face on the mill using the soft jaws to hold the pulley. Or you could send out the job and have it cold sawed.
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 16-12-2011, 10:20
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: Timing Pulley Stock - Machining Question
You can machine an arbor to press into the bore. Use larger diameter stock so you will form a shoulder. Keep its length close to bore length and machine along with pulley width reduction.
PS You can wrap the pulley with aluminum sheet to form a shell so the 3 jaw chuck will seat against the same thickness material when bridging the odd tooth location. Have also made aluminum slip rings with a thin slot cut that the chuck jaws can compress onto the pulley teeth equally. Make the bore of this adapter slightly smaller than the pulley ID for a tight fit. Do not use tailstock/drill to open up bore. Get a boring tool for proper concentricity.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 17-12-2011, 10:50
Dick Linn's Avatar
no team (Synergy)
I'd consider making a "key" that somewhat fit the gap between the teeth. It could be aluminum or soft copper wire. Hammer and file to fit somewhat, the height being a bit hit-or-miss. Don's idea is better if you have the material. Be safe!
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
