Go to Post Different strokes for different folks. - Madison [more]
Unread 23-11-2011, 11:17
linuxboy linuxboy is offline
AKA: Oliver Graff
FRC #3780
linuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud of
Re: Developing an iOS based FRC network monitoring tool
Getting through the encryption is easy, just sneak into the event Wednesday night and grab your WPA key from FMS
I wish it could be used at events however, like you said, teams are not given the encryption key. I imagine the use case for this to be when teams are testing out their robot at home and want to get a view of what is going on on the network, or troubleshoot it if there is an issue. Another use for this (even though currently it only shows one robot at a time) would be a field monitor for offseasons that do not have an FTA. I think though, that it may be better to make a separate app for monitoring the entire field for offseasons than using this for it, but I'll see how much free time I have .
Oliver
