Go to Post If your robot doesn't work, it doesn't matter, because the robot is really meaningless, in the long run. What is the important thing, the reason we're all in FIRST then? To better our understanding of Science and Technology, and hopefully make the world a better place. - Ian W. [more]
  #31   Spotlight this post!
Unread 23-11-2011, 02:02
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Re: Swerve Drive
Originally Posted by Aren_Hill View Post
I've used bevel gears 3 times in competition and have never had a problem with them, in the above pictured setup we only had issues with the utterly ridiculous chain runs.
Looks like you took extreme care to make sure they stayed aligned—the keyed profile on the quarter-inch plates is a fantastic way of implementing that. I often worry about the torsional rigidity in the modules we occasionally see posted here.
  #32   Spotlight this post!
Unread 23-11-2011, 08:27
Joining the 900 Meme Team
FRC #0079
Re: Swerve Drive
Originally Posted by JDNovak View Post
As for crab vs swerve. The code to steer from straight through an arc to rotating around the center of the frame has taken years to perfect. Actually, we had the trig working on the Basic Stamp in 1999 but changed to look up tables through the PIC years. We finally got a better version of real time trig working last year. Crab, on the other hand, takes about 10 minutes to point all the wheels in the same direction and turn all the wheels the same speed.
This is interesting, I was under the impression that the STAMP did not have math libraries included whereas the PIC did. I know the programmer on 27 was very happy to have the math libraries on the PIC. Of course, not only is this a long time ago but it was also when I was much younger and wasn't really paying too close attention to him so I could be very much mistaken.
It does show how far the controllers in FRC have come though.
  #33   Spotlight this post!
Unread 23-11-2011, 09:18
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: Swerve Drive
Aren - how much did that swerve drive base weigh? I'm just curious.
  #34   Spotlight this post!
Unread 23-11-2011, 10:17
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Re: Swerve Drive
To use the STAMP2 you had to get into the PBASIC Zen Mode. It was all unsigned 16 bit math and it tooks some discipline to keep from hosing yourself. I can recall pulling my hair out trying to count/balance/place the nested parens (which I eventually gave up on -- I memorized the evaluation order of operators and basically kept parens down to the absolute minimum - took some doing but it was a time and bug saver in the end)
As to being glad to see the STAMP2 in the rear view mirror? You bet. It was some much easier to do things like scale a joystick using signed math. Oh and the PIC chip was many many times faster, more memory for variables, more code space (remember program slots? Ugh! that was painful).
Joe J.
Team #88, TJ2
  #35   Spotlight this post!
Unread 23-11-2011, 10:24
FRC #0079
Re: Swerve Drive
Joe J.
This makes me glad I only ever used the PIC based stuff.
  #36   Spotlight this post!
Unread 23-11-2011, 10:28
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Re: Swerve Drive
Joe J.
I recall when 95 did a swerve drive using the basic stamp in 2003. I soldered up a board to use a second stamp in parallel with the RC in order to speed up our processing time. It was a nightmare from what I recall.
  #37   Spotlight this post!
Unread 23-11-2011, 11:38
Aren_Hill's Avatar
Build Nifty Things
Re: Swerve Drive
Never got a weight on just the chassis, but my estimates put it around 45lbs.
Currently rebuilding the practice chassis into a 4wd completely independent swerve for controls development, so I can probably get a weight on that later this week.
I've got a few new concepts in mind that would bring an 8 motor swerve down to 30-35lbs
A guy who likes robots.
  #38   Spotlight this post!
Unread 23-11-2011, 15:34
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
Re: Swerve Drive
http://www.chiefdelphi.com/media/papers/2378
http://www.chiefdelphi.com/media/papers/2381
Here is a paper and presentation from a few years ago that you can review.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
