Go to Post I have many ideas, every last one of them involves finding something more productive to do with your time. - Andrew Schreiber [more]
Unread 22-11-2011, 18:52
KimoJosh KimoJosh is offline
FRC #2439
KimoJosh is an unknown quantity at this point
Convert AutoCaD to Inventor
How do you change an AutoCaD file (.dwg) to an Inventor file (.ipt)??
Unread 22-11-2011, 19:14
Re: Convert AutoCaD to Inventor
You can try doing a Save As in AutoCAD. If you can't save it as an Inventor file, you should be able to save it as a STEP File, which Inventor can open. Open with Inventor and save as an Inventor file.
Unread 22-11-2011, 21:28
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
I'm pretty sure you can import a DWG into Inventor. I can't check this out now, because my computer is in between versions (my 2010 expired, and I've been to lazy to download 2011). Look for the Import function, and you should be able to choose a DWG.
Unread 23-11-2011, 08:57
FrankJ's Avatar
FrankJ FrankJ is offline
Robot Mentor
FRC #2974 (WALT)
Inventor will open .dwg file. Then save as an inventor file.
Unread 23-11-2011, 10:12
scottydoh scottydoh is offline
CAD, Mechanical, Alumni, Mentor
AKA: Scott
FRC #0810 (Mechanical Bulls)
scottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to all
Send a message via AIM to scottydoh Send a message via Yahoo to scottydoh
OP This is good if you're working with solids, if its only 2d you can just import the .dwg file like the previous posters stated.
www.smithtownrobotics.com
Robot Inspector (SBPLI 2011)
2011 Johnson & Johnson Gracious Professionalism (NYC) Judges Award (SBPLI)
2009 Xerox Creativity (SBPLI)
Mechanical Bulls; Student Leader 2006-2008, Mentor 2009-Present
New York Institute of Technology - Architecture '13 | Design Portfolio:www.coroflot.com/sdifiore
Unread 24-11-2011, 20:45
JD Mather's Avatar
JD Mather JD Mather is offline
JD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the rough
Select the dwg file to open.
Click Options (before opening).
Set to Import.
Finish opening.
Save in Inventor.
Autodesk Inventor Certified Expert
Certified SolidWorks Professional
AU 2007 Avatech Altogether Smarter Inventor Challenge 1st Place
http://home.pct.edu/~jmather/content..._tutorials.htm
