Go to Post I have learned so much from this program and am forever changed by FIRST and its community. You have made me a better person in so many ways. Thank you. - Jessica Boucher [more]
Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
Unread 25-10-2011, 11:11
austin1743 austin1743 is offline
Head Programmer - Java
FRC #1743
austin1743 is an unknown quantity at this point
help with mecanum drive code
Hello, I am doing some off-season coding practice but I keep getting an error that i have been stumped on, Can someone help me out? just some tips or a way to go about it.
So far i have:
// things below this need to be imported first
package edu.wpi.first.wpilibj.templates;
import edu.wpi.first.wpilibj.Dashboard;
import edu.wpi.first.wpilibj.DriverStation;
import edu.wpi.first.wpilibj.Victor;
import edu.wpi.first.wpilibj.IterativeRobot;
import edu.wpi.first.wpilibj.RobotDrive;
import com.sun.squawk.util.MathUtils;
public class RobotTemplate extends IterativeRobot {
* This function is run when the robot is first started up and should be
* used for any initialization code.
RobotDrive m_robotDrive;// robot will use PWM 1-4 for drive motors
//declears speed controllers
Victor leftFrontspeed = new Victor(4, 1);
Victor rightFrontspeed = new Victor(4, 2);
Victor leftBackspeed = new Victor(4,3);
Victor rightBackspeed = new Victor(4,4);
DriverStation driverStation; // driver station object
Dashboard dashboard;
// Declare variables for the two joysticks being used
Joystick js1; // joystick 1 (arcade stick or right tank stick)
public void teleopPeriodic() {
// leftspeed.set(js1.getY());
// rightspeed.set(js1.getY());
//is called when teloporated mode is enabled
double lf;//is what will be set to the left wheel speed
double rf;//is what will be set to the right wheel speed
double lb; // is what will be set to the left back wheel speed
double rb; // is what will be set to the left back wheel speed
double y = js1.getY(); //gets the value of the 1'st joystick's y axis
double x = js1.getX();//gets the value of the 1'st joystick's x axis
//y = y * Math.abs(y);//makes the y value quadratic
//x = x * Math.abs(x);//makes the x value quadratic
x=-x;
//begins meckanum code which I do not understand but it works
double magnitude =Math.sqrt(js1.getY()*js1.getY()+js1.getX()*js1.ge tX());
magnitude = magnitude*Math.sqrt(2);
double rotation = js1.getTwist();
double direction=MathUtils.atan2(x, y);
double dirInRad = (direction+45);
double sinD=Math.sin(dirInRad);
double cosD=Math.cos(dirInRad)*Math.sqrt(2);
lf=-sinD*magnitude+rotation;
rf=-cosD*magnitude-rotation;
lb=-cosD*magnitude+rotation;
rb=-sinD*magnitude-rotation;
//ends mecanum code
//lf=y;
//lb=y;
//rb=y;
//rf=y;
//runs function limit to ensure the speed of the motors is in exceptable range
lf =limit(lf,1,-1);
lb =limit(lb,1,-1);
rf =limit(rf,1,-1);
rb =limit(rb,1,-1);
//sets the motors speed
leftFrontspeed.set(lf);
leftBackspeed.set(lb);
rightFrontspeed.set(-rf);
rightBackspeed.set(-rb);
System.out.println("js1.y:"+js1.getY()+"\t js1.x:"+js1.getX()+"\t lf:"+lf+"\t rf:"+rf+"\t lb:"+lb+"\t rb:"+rb);
I get the errors saying that the following lines of code are "Cannot find symbol". I do what netbeans wants me to do and it makes a class for it but then i get a lot more errors.
If someone has just a standard drive code i can look at please refer me to that link.
thanks a lot.
Last edited by austin1743 : 25-10-2011 at 21:13. Reason: edited code to bring up to recomendations
Unread 25-10-2011, 16:43
Re: help with mecanum drive code
Where is js1 declared?
Unread 25-10-2011, 18:24
FRC #1743
thanks, i didn't even catch that, i had it in my first code document but not in the second...
public void robotInit() {
/**This function is called periodically during operator control
x=-x;
//ends mecanum code
//lf=y;
//lb=y;
//rb=y;
//rf=y;
lf =limit(lf,1,-1);
lb =limit(lb,1,-1);
rf =limit(rf,1,-1);
rb =limit(rb,1,-1);
I have put in the js1 (joystick 1). I have also highlighted (in bold) where I am getting my error at.
Unread 25-10-2011, 18:32
JosephC's Avatar
JosephC JosephC is offline
FF: Breakfast Company
AKA: Joseph Cupchack
no team (FiM Volunteer Extraordinaire)
JosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond repute
Mecanum in a nutshell
magnitude = leftStick.getMagnitude();
direction = leftStick.getDirectionDegrees();
rotation = rightStick.getX();
driveRobot.mecanumDrive_Polar(magnitude, direction, rotation);
Referee: 2015 - ?
Field Reset/Supervisor: 2013 - ?
68 Team Member: 2011 - 2013
Unread 25-10-2011, 21:23
FRC #1743
Ross, i have added the js1 (joystick1) into the code thanks for catching that
Joseph thanks for the mecanum in a nut shell. I know mecanum wheels have some weird math vectors behind them which i sort of understand but how does that relate to the controller? I ask this as I am a little confused on why the code would have magnitude from the controller?
Unread 25-10-2011, 21:33
If the driver is using a joystick, the magnitude can be computed using sqrt(X^2+Y^2), or perhaps max(abs(X),abs(Y)). That is used as a speed command - how fast the driver wants the vehicle to go.
The direction is computed using for example theta = atan2(-Y,X). It is the clockwise angle with zero in the forward direction. It is the driver command to tell which direction the driver wants the vehicle to move.
Unread 25-10-2011, 21:43
FRC #1743
thanks Ether for the explanation.
I am going to try the code out soon to see if it works on our robot.
Unread 12-11-2011, 18:41
FRC #1743
Ok well, unforntanetly i gotta wait to test this on our robot....
But i have come across some errors in the code.
The error i am getting is on: Public class Robot extends IterativeRobot {
is says that a class or interference expected..
you can see the java code in the google doc at:
https://docs.google.com/document/d/1...fpFrrftRQ/edit
I believe it maybe just a file i got spelled wrong but i am checking on that...
Team 1743
Head Programmer
Unread 24-11-2011, 22:06
Djur's Avatar
Djur Djur is offline
WPILib
AKA: Sam Carlberg
Djur will become famous soon enough
This is our team's custom mecanum code:
jaguarDrive((jX+jY)/2, (jY-jX)/2, -(jY-jX)/2, -(jX+jY)/2);
jX and jY are just the X and Y coordinates our joysticks read (-1 through 1).
And the jaguarDrive method:
public void jaguarDrive(double FL, double RL, double FR, double RR)
        m_frontLeftMotor.set(FL);
        m_rearLeftMotor.set(RL);
        m_frontRightMotor.set(FR);
        m_rearRightMotor.set(RR);
This is by far the simplest solution I've seen.
WPILib dev (RobotBuilder, SmartDashboard, GRIP)
Unread 24-11-2011, 22:36
It's simple because you're only commanding 2 degrees of freedom.
Unread 24-11-2011, 22:42
Djur's Avatar
WPILib
AKA: Sam Carlberg
What other degrees of freedom are there, though? Turning is simple enough and isn't the topic of this thread anyhow.
Unread 24-11-2011, 22:49
The code you posted commands only translation (fwd/rev & left/right), no rotation.
The topic of this thread is "help with mecanum drive code", so yes turning is part of mecanum drive code.
Adding rotation to the mix is not difficult. Simple code for that has been posted elsewhere.
Unread 24-11-2011, 22:52
Djur's Avatar
WPILib
AKA: Sam Carlberg
Ah. Then I should just add that by setting FL, RL, FR, RR to the same value will make the robot turn. Positive values turn the robot counterclockwise, negative values turn it clockwise (assuming the motors are hooked up correctly).
Very simple example use for turning:
boolean turnRightAtFullSpeed = true;
if(turnRightAtFullSpeed)
jaguarDrive(-1, -1, -1, -1);
Unread 24-11-2011, 23:03
Ah. Then I should just add that by setting FL, RL, FR, RR to the same value will make the robot turn. Positive values turn the robot clockwise, negative values turn it counterclockwise (assuming the motors are hooked up correctly).
jaguarDrive(1, 1, 1, 1);
If you want full 3 degree of freedom control (rotate while translating), you should either use the provided WPI library codes for mecanum, or do something like this:
"y" is the forward command
"x" is the strafe right command
"z" is the rotate clockwise command
Step1:
Compute the 4 wheel speeds:
FL = y + x + z
FR = y - x - z
RL = y - x + z
RR = y + x - z
Step2:
Find the max absolute value of the above four commands,
and if it is greater than 1,
divide all four commands by that max absolute value.
Unread 24-11-2011, 23:15
Djur's Avatar
WPILib
AKA: Sam Carlberg
Step1:
FL = y + x + z
FR = y - x - z
RL = y - x + z
RR = y + x - z
Step2:
That's very interesting, although I see no point at which a robot would need to do that except for showing off.
