Go to Post You just have to care enough to give it a try. Your mentors will appreciate the effort. - Koko Ed [more]
Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
Unread 24-11-2011, 22:52
Djur's Avatar
Djur Djur is offline
WPILib
AKA: Sam Carlberg
Djur will become famous soon enough
Re: help with mecanum drive code
The code you posted commands only translation (fwd/rev & left/right), no rotation.
The topic of this thread is "help with mecanum drive code", so yes turning is part of mecanum drive code.
Ah. Then I should just add that by setting FL, RL, FR, RR to the same value will make the robot turn. Positive values turn the robot counterclockwise, negative values turn it clockwise (assuming the motors are hooked up correctly).
Very simple example use for turning:
boolean turnRightAtFullSpeed = true;
if(turnRightAtFullSpeed)
jaguarDrive(-1, -1, -1, -1);
WPILib dev (RobotBuilder, SmartDashboard, GRIP)
