Go to Post It is not necessary to draw 200 amps to move a robot through a two minute match. Rule of thumb is you robot should be able to compete for three matches without a battery change. - Al Skierkiewicz [more]
Unread 26-11-2011, 00:25
Toggling RS232 RTS pin on WinXP machine using Java
Hello Java-on-Windows gurus.
Is there a simple way, in Java, to access an RS232 port on a WinXP machine for the sole purpose of toggling the RTS pin?
