Go to Post P.S. While I doubt Karthik's "Delgado" jersey would go for $500,000... it would be much cooler to see Carlos Degado wearing a "Kanagasabapathy" jersey. THAT I might pay for! - dtengineering [more]
Unread 26-11-2011, 10:28
SciBorg Dave SciBorg Dave is offline
AKA: Dave Tharp
FRC #5920 (VIKotics)
SciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to beholdSciBorg Dave is a splendid one to behold
NEW TEAM NEEDS
We are a very new team in rural Eastern Washington.
I would like to know what extra parts (to have on hand) will be needed for the the robot build ?
Please give what extra parts might be needed and a source for the parts, we will need to shipping in everything no local sources.
This may save us a lot of down time in January and Feburary.
Thanks FIRST TEAM 4061 SciBorgs.
Unread 26-11-2011, 12:16
Re: NEW TEAM NEEDS
Aluminum (tube and angle, probably in the 1" square range)
Plywood/Lexan (anybody using acrylic/plexiglass is asking for a failure)
Fasteners
PVC in some cases
Pool Noodles. (These will be used in bumpers. Leftovers make decent shock absorbers for mechanisms that might hit the frame.)
Tools to work with above (saws, drills, drivers)
As far as sources, McMaster-Carr is a little expensive, but has very fast shipping. For stuff on the above list other than aluminum, the nearest home-improvement store should have it (though that might still be a long way)--bear in mind, you'll probably need a lot of plywood to build field elements as well as parts on the robot.
As a rookie team, I would not recommend doing anything overly complicated. Kitbot or Kitbot on Steroids drivetrain (you get all the parts for the former in the kit), a basic manipulator, and plenty of practice will serve you as well as anything more complicated.
Unread 26-11-2011, 17:00
AKA: Dave Tharp
Re: NEW TEAM NEEDS
What size fastners do the teams use the most of ?
Were can you get aluninum on line ?
Looked at McMaster- Carr could not find pool noodles ?
A basic manipulator ?
We hope to do a lot of pratice !
Unread 26-11-2011, 17:08
Re: NEW TEAM NEEDS
Fasteners vary. It really depends on your team's needs. Whatever comes in the kit of parts, though, you may want more of.
McMaster may or may not have pool noodles, but you do need to get pool noodles. McMaster does carry some aluminum; however, there are places online. (I've never dealt with any myself, but there are a number of posts on CD with places to find some.) Try a pool supply store for the noodles.
A basic manipulator--Something fairly simple that can handle the game object in the way that the game requires. That's something you'd design after Kickoff.
Unread 26-11-2011, 18:19
slijin's Avatar
slijin slijin is offline
Pockets
AKA: Samuel Lijin
FRC #0694 (StuyPulse)
Re: NEW TEAM NEEDS
We tend to mostly use 1/4-20 hardware, augmented with assorted bits of either 6-32, 8-32, 10-24, and 10-32 depending on the application; we rarely ever use more heavy-duty bolts & nuts. I suggest you read up on the different types there are and buy accordingly. You may want to collaborate with local teams (if there are any) to see how they obtain their hardware.
Keep in mind that fasteners are not, however, limited to bolts and nuts. Other commonly used ones include rivets (most FIRST teams use pop rivets, which are much easier to use) and sheet metal screws (there is a fine distinction between these and bolts & nuts), as well as Velcro (you'd be surprised how strong the industrial stuff is).
We like to use onlinemetals.com for our aluminum, but McMaster has the fastest turnaround time, so it's worth the price if you need something fast.
A bit of stock plywood would also come in helpful, not only for prototyping but occasionally even in the final bot.
2010-12 CT Chairman's
2011 Galileo 5th seed
2010 NY Regional Winners
Unread 26-11-2011, 18:23
Marc S.'s Avatar
Marc S. Marc S. is offline
Read the Manual! PLEASE!
AKA: Adversity
FRC #3925 (Robotics)
Marc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond repute
Re: NEW TEAM NEEDS
Something that will give you a competitive advantage is building a practice bot. As a rookie team this is harder for you to accomplish but if you use the same electronics and (in some cases) the same mechanical structures it can be done cheaply. And definitely use this.
Alumnus FRC 973: 2010, 2011, 2012, 2013
2011 World Championship Winning Alliance Member
FLL Mentor and Competition Judge 2012-2015
Student-Mentor FRC 5102: 2014, 2015
Student-Mentor FRC 3925: 2015, 2016
FRC Ventura Regional Planning Committee Member & Regional Field Supervisor: 2015, 2016
Unread 26-11-2011, 23:13
AKA: Dave Tharp
Re: NEW TEAM NEEDS
OK I want to order some metals.
What size, What number(6061 -6063), How long ?
You got the team going what else will we need ?
Do we do a 2nd robot?
Unread 26-11-2011, 23:29
Re: NEW TEAM NEEDS
This is a rather involved set of questions this time. I'll do my best, but you're starting to get into details here.
The number is the alloy. There will often also be some form of hardness number following the alloy. 6061 is adequate for FRC applications, as is 6063. There are other alloys with different properties. Going into what all the alloys and their numbers mean... well, that's a materials course and a mechanics of materials course.
Length: Just get the "stock" size if it's anywhere longer than 3-4'. Often, metal is sold in 10' lengths; getting a few of those will help you later.
As far as size... It really, really depends on the application. 2"x1"x1/8" isn't uncommon for drivebases; 1"x1"x1/8" or 1/16" isn't uncommon in the superstructure. If you're going with a kit drivebase, which includes its metal, then I'd get 1"x1"x1/8" in both square tube and angle shapes.
If you have the resources, yes. If you don't have the resources, don't. In this case, I'd suggest not until after you've built your primary robot, and put all your effort towards getting a running robot ASAP and getting some practice on that, on carpet.
Mentors, a mentor team, some luck... Oh, and grab some parental involvement if you can.
Unread 26-11-2011, 23:40
AKA: Dave Tharp
Re: NEW TEAM NEEDS
We have a great group of mentors 12
Great students approx 34
Volunteers (parents) 22
We will not be able to get into our build area until Dec 20th
This is a lot of working getting a team going.
FIRST TEAM 2016 is sending us some parts to look over.
Just want to get as much ready for the team before Jan.7th
We do not know what is in the KOP so we start from the ground and work up.
If anyone has more ideas PLEASE send them in.
Unread 26-11-2011, 23:51
Re: NEW TEAM NEEDS
Oh, I have ideas. Check your PM box.
One of those ideas is that it may be worth your while to look at the Administrative Manual (2012), if you haven't already. Another is that the 2011 Manual may be decent reading, particularly the KOP and Robot Quick Build documents. Note that the Manual itself will not apply to 2012, though some of the other documents might.
Unread 26-11-2011, 23:54
Marc S.'s Avatar
AKA: Adversity
Re: NEW TEAM NEEDS
Try to get 6061 alloy. 6063 takes longer to machine and tends to gum up machine cutters more. If the size you need doesn't come in 6061 don't spend too much time trying to find it. Having your own machines definately changes what and how much you buy.
973 builds their frame mainly out of 2x1 and 1x1 tubing, 1/16 and sometimes 1/8 wall thickness. We also use just about every size from 1/8x1 to 3x3 solid. After a couple seasons you should have a full list of material to suit your design style.
Check out our cad.
Unread 27-11-2011, 00:12
AKA: Dave Tharp
Re: NEW TEAM NEEDS
How about extra battries and extra charger ?
FIRST 4-H TEAM 4061
Unread 27-11-2011, 00:24
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is online now
45 Alumni
AKA: Peyton Yeung
Re: NEW TEAM NEEDS
FIRST 4-H TEAM 4061
I would definitely suggest extra batteries and chargers. Our team has a 6 chargers and about a dozen batteries(probably overkill).With our 2nd bot we do a lot of driving and practicing so we go through batteries quite quickly.
461 Westside Boiler Invasion
45 Technokats
Unread 27-11-2011, 00:30
Re: NEW TEAM NEEDS
*facepalm* I forgot all about that!
Not knowing what the charger is that comes in the rookie kits these days, I would definitely get another one (I think there's been discussion on CD of various types of chargers and charge rates--a CD search should turn up those threads).
Batteries: You'll get 2, as a rookie; the Manual will tell you what the accepted additional batteries are. They'll be 12V motorcycle batteries, unless something changes. Get 2-4 extras, and consider getting a battery tester, if not this year then soon, to verify that they're working properly. Then set up a battery management system so you know that you've got a good battery every match.
Oh, there is one other place you will want to get VERY familiar with. http://www.andymark.com/ These guys sell motors, gearboxes, chassis systems, batteries... They are also, to some extent, FIRST's "surplus" or "outlet" for game pieces if those aren't readily available, and for the FIRST Choice kit additions. Got an extra couple thousand dollars lying around? Get a complete chassis and build a practice drivebase. Need mentoring? Though that is better done locally, Andy and Mark are both experienced mentors. Can't find assembly instructions for the KOP gearbox? They'll be on that site. Quality is excellent, and customer service is outstanding.
Unread 28-11-2011, 07:34
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Re: NEW TEAM NEEDS
10-32 can be used for almost every need. You will need some 1/4-20 and 3/8-16 if you use the kitbot.
If possible use all the same fastener or as much of one as possible because you will spend less time looking for tools if they all need the same allan key and box wrench. You can minimize loose parts by using flange head bolts to eliminate washers also.
http://www.mcmaster.com/#socket-head-cap-screws/=f4o3m4
Thank-you 294 & 67
www.bobcatrobotics.org
