Go to Post Every team in FIRST can make this choice. Be positive, help others, and work like a maniac behind the scenes. This approach will bring you joy and satisfaction, whether you win or not. - OZ_341 [more]
Unread 27-11-2011, 22:32
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Interrupts
Has anyone tried to use the interrupt functionality of the WPILib directly? Let me see if I have this straight:
  • There are six interrupts available on GPIOs 1-6 [source - page 59] However, if that's true, why can we attach a encoder anywhere?
  • To get a function called whenever the pin changes state, the function RegisterInterruptHandler must be called
  • No interrupts can happen while another is in progress.
Also, I was wondering about calling a Relay.Set() function in an interrupt - would that take too long? How would it be possible if the relay was a private member of the class?
Thanks!
Unread 27-11-2011, 23:54
Re: Interrupts
Thanks!
The WPILib document you referenced is for the IFI system.
Unread 28-11-2011, 02:10
WizenedEE's Avatar
AKA: Adam
Re: Interrupts
Oh okay, thanks. I was expecting something like that. Is there another document that shows how to use interrupts? I am starting to piece things together, but it would be helpful if someone who has done this would share their experiences.
Specific question:
I just looked at the tInterruptHandler typedef, and I'm wondering what interruptAssertedMask would pass.
Unread 29-11-2011, 17:18
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: Interrupts
Have you looked at the InterruptibleSensorBase class yet? It is a base class for the DigitalInput class. You can choose to block until the interrupt or register a callback on interrupt (based on which version of RequestInterrupts() you call).
-Joe
