Go to Post Once you have a lathe you'll wonder how you ever got through life without one. - Wayne TenBrink [more]
Unread 27-11-2011, 23:42
nnfuller's Avatar
nnfuller nnfuller is offline
AKA: Alumni
FRC #2733 (Pigmice)
nnfuller is on a distinguished road
Purchasable Tricks and Easy Fixes
So I have been helping budget for our next season, and I was thinking that maybe the CD community could help. I wanted to create a list of things that can help a team during the build season. My favorite example of this would be the plastic air tanks that arrived mid season last year. I was wondering if there were other links that solve common problems.
These problems might include but are not limited to:
  • Weight Savings
  • Chain Tensioning
  • Non-Traditional Gearboxes
  • Wheel Sources (Not Andymark or IFI)
  • Sensors
  • Tools
Thanks for the help!
Nathan
Unread 28-11-2011, 09:21
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Purchasable Tricks and Easy Fixes
I have to warn you that there are many red herrings in any sort of list you'd get. There ain't no such thing as a free lunch -- but there are cheap lunches. For example, I'm willing to bet my BBQ pulled turkey lunch today that many, many hours were spent searching for an air tank that would fit the needs of a team within our rules before the white fiberglass ones were actually found. Many other 'tricks' (such as the Dark Soul Chain Breaker) have caveats like "#25 chain is the ficklest $#*! chain you'll ever use -- 1 degree out of alignment or 1/4" too much slop and it's guaranteed to come off!".
That being said, the Dark Soul tool worked great until we lost it, heh. We're going to get a new one soon. The caveats: #25 chain is the ficklest $#*! chain you'll ever use. The sprocket teeth are so shallow that even the slightest imperfections in your robot production process will show up at the most inconvenient times.
If you need thin, strong boards that can hold the weight of a robot (like ramps for 2007), then honeycombed fiberglass may be a good fit. We've also use it for our electronics boards since 2007. This year we might use something different. The caveats: it shears very easily, so use wide washers at every mount point; it is not meant to be a structural member that can withstand impacts, so the weight it carries should be light during all interactive times of play.
GitHub
Last edited by JesseK : 28-11-2011 at 16:46. Reason: bet my turkey lunch, not BE it .... heh
Unread 28-11-2011, 14:26
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
I'll also caution you that any list you come up with may not be valid next year - rules always change. Last year was the first time those plastic air tanks are a prime example - last year was the first time they were legal. I know (from personal experience as an inspector) that they were a huge pain during inspections. Speaking personally (I have NO insight into the GDC or what they're thinking on the rule book), I wouldn't be surprised if that specific rule changes again this year to help make things run a little easier... It's just a nightmare for both inspectors and teams to trace those plastic air tanks back to specifications and show that they are rated for the appropriate air pressure.
Unread 28-11-2011, 14:48
Joining the 900 Meme Team
FRC #0079
[*]Weight Savings - Freshmen with a hole saw? But there is no easy way of doing this, a lot of it requires you to do the math to figure out exactly what material you need and how much of it. Be very careful here.
[*]Chain Tensioning - AM sells a chain tensioner that works reasonably well. You could also just design for an integer number of links between the wheels and be done with it. According to some discussion on last night's cast #35 chain will just deal with it.
[*]Non-Traditional Gearboxes - Dewalts were pretty popular for quite a few years. However, in my experience, the majority of top tier teams use the AM guts with a custom housing. A few build completely custom ones nowadays but the need to do that is diminishing. As far as other sources. Banebots is TECHNICALLY a source but there are a lot of people on these forums that have some very creative words for BB transmissions.
[*]Wheel Sources (Not Andymark or IFI) - Colson wheels. Literally worst kept secret in the NE region. Avoid BB wheels, they tend to shred. Probably would work ok for grippers though. Some teams have been going back to the old school pneumatic tires but they are by no means easy as interfacing with them has, traditionally, been a pain.
[*]Sensors - Sparkfun Electronics. Incredibly support, reasonable prices, and probably the coolest shipping boxes in the industry. Most of their stuff is of decent quality, I've never had any problems with them. Just don't order resistors or leds from them, their prices are a little steep.
[*]Tools - Can't help ya here.
Not really a list of easy fixes or quick purchases that will turn you into the next 254 but it should point you to some alternate options you can utilize in the future.
Unread 28-11-2011, 15:21
Corrugated plastic, properly supported by frame, is similar, but maybe a bit tougher. You still need the washers (the plastic crushes a bit), but it can take a pretty tough impact. 330 used it for ramps in '07.
Unread 28-11-2011, 15:28
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
We prefer the Unibit (aka stepdrill):
http://www.irwin.com/tools/browse/dr...it-step-drills
These are safer and easier to use than hole saws when your holes are in the correct size range.
Tensioning is easy to do with various size delrin idelers. Just swap in different ODs to in crease or decrease tension.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 29-11-2011, 16:55
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
As did 696 with great success. Good stuff.
Unread 29-11-2011, 17:23
Chris is me's Avatar
AKA: Pinecone
A neat little known product: IFI sells pre-punched C-channel and gusset plate that basically looks like Vex on steroids. If I was on a team with a bit of cash and no mill, I'd certainly strongly consider it as a general frame material.
Unread 29-11-2011, 18:34
George C's Avatar
George C George C is offline
AKA: George Chisholm
FRC #1360 (Orbit Robotics)
George C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to behold
We had great success with some new (to us) products last year:
Garolite sheet available from McMaster Carr. We used it for paddles on our gripper. Easy to work with, very strong and a lot cheaper than carbon fibre
Constant force springs available from McMaster Carr. Helped counterbalance our 3-stage elevator
Igus linear slides available from Igus. Used in our 3 stage elevator and our mini-bot deployment system.
I echo the comment on step drills, plastic air tanks and UHMW plastic spool and cam-type chain tensioners.
Surgical tube is wonderful stuff. Many strengths at McMaster Carr and elsewhere
Unread 29-11-2011, 19:37
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
Some great things we always use:
- echo the Dark Soul chain tensioner: We have 2 or 3. We always use seemless chain and hardly ever lose chains. (Not one all last season.)
-Surgical tubing: Used for counterforce, passively springing something, and battery straps(<-this works really well) among other things. We always have this on our robot usually serving multible functions.
-Polyurthane belting: this is the choice material for convayer belts such as 2009. However, it is also great for powering rollers in other applications and can act as a mechanical clutch if desired. In 2011 this powered our claw as well as provided the grippy surface for the tubes. It also allows for figure 8 belts which can make it better then chain in some applications. We also always have some of this on our robot every year.
-lexan: This has a variety of uses not the least of which is an electronics cover. We always use this for decorative body panels however, do to its flexable nature it is also VERY durable in the 1/8 - 1/4 size range. We also used 1/8 as the entire bottom half of our claw in 2011 and It never broke once. It is also quite light which makes it a pretty great building material in the correct applications. We definatly use this every year on the robot.
-velcro: its great for things that are often taken on and off the robot. We use it especially for bodypanels.
-Zipties: Especially the high strength ones. In 2008 we held togeather our elevator with zipties for the remainder of competion after it was sheared off by the overpass in elims.
-1"x1"x1/16" L brackets: You can't buy them, however its great to have a bunch pre-made. Every year we usually have a couple of these on the robot. They are also great for prototyping. The first thing freshmen make in the shop is always these, and they always seem to get used up.
Good Luck, Bryan
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
Unread 29-11-2011, 19:50
AlecMataloni AlecMataloni is offline
Excellence is Bliss
AlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond repute
If you don't already use them, the Anderson Powerpole Connectors are a MUST HAVE for any team's wiring! They make replacing motors, speed controllers, and other important electrical components parts much easier, faster, and safer.
Here's a guide from the FIRST website related to them. At the end, it tells you where you can purchase the connectors and the related crimping tool. http://www.usfirst.org/sites/default...pole-Guide.pdf
Unread 29-11-2011, 20:49
AKA: Pinecone
We successfully received sponsorship from Anderson Power Products last season and got our connectors all for free. This has been more useful than I could have imagined. We have a single, asymmetrical electric "plug" on our robot with connectors attached to each other that allows us to remove our electronics board from the robot with one click. I would recommend it especially to teams without a practice set of electronics.
Unread 29-11-2011, 22:51
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
The fiberglass laminate is awesome. It can be custom made too, with various skins and cores if one is so inclined.
To solve the bearing stress issues (fiberglass sheets are actually very strong in shear if laid up anisotropically) using a big washer clearly works, but a stronger solution is to epoxy the washer in place. Or better yet epoxy a bushing in place to prevent crushing the board. Smaller washers/bushings could probably be used if they are glued, to save weight.
Unread 30-11-2011, 07:31
We have a mill and welding capability yet we use this on many of our robots to save time. FYI IFI calls it SuperVEX in house.
Thank-you 294 & 67
Unread 30-11-2011, 23:55
remulasce remulasce is offline
remulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to beholdremulasce is a splendid one to behold
Double stick tape was influential in keeping sensors, motor controllers, and joysticks attached where they should be, while also serving as a structural component in minibots and our "borrowed" minibot deployer.
Student 294: 2007-2011
Mentor 597: 2013-2015
Google SWE: 2015-
