Go to Post actually, I don't work with mechanics, so I just barely learned what Lexan was a few days ago...long story... It's amazing the variety of things FIRST teaches us!!! - tribotec_ca88 [more]
Unread 28-11-2011, 22:16
Andrew Lawrence
Posts: n/a
Bumpers w/pneumatic cylinders
I've had this idea of placing pneumatic cylinders behind our bumpers (see below) for a few possible applications:
1. Shock absorbers: Add a bit of air to small cylinders, small enough to make only a small difference in bumper width from the robot, and use them as shock absorbers for collisions.
2. To use as a "defensive push": Basically, add the cylinders to the the bumpers, and when someone gets a little too close for comfort, we just launch out our bumpers. This could also be used to redirect another robot, or to assist in a pin.
What do you think? Is it legal?
Attachment 11133
Unread 28-11-2011, 22:20
Duke461's Avatar
Duke461 Duke461 is offline
Boiler Strong.
AKA: Ben Carson
Duke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond repute
Re: Bumpers w/pneumatic cylinders
Someone will probably get a more technical definition soon, but im too lazy .
The first thing you need to remember is that bumper rules change from year to year, so you can't rule out anything yet.
However, using the 2011 rules, I would say illegal, because there would in a sense be "gaps" in you robot. see here.
Hope this helps,
-duke
EDIT: This should help a lot:
The opposite of excellence is good enough.
2012-2013 President; 2011-2012 Vice President
2011-offseason FRC Student Drive Coach; 2010-11, 2011-2012 VEX Drive Coach
2011, 2010-offseason FRC Driver/Operator
2012, 2011-offseason, 2010-offseason FRC Human Player
Find me on: Facebook, Gmail, Twitter, Tumblr, Blogger/Blogspot
Unread 28-11-2011, 22:21
Andrew Lawrence
Posts: n/a
Hope this helps,
-duke
And if you make it so the bumpers go over the gap length?
Unread 28-11-2011, 22:24
Duke461's Avatar
Boiler Strong.
AKA: Ben Carson
Im not sure what you mean here, sorry.
Unread 28-11-2011, 22:26
In past years, you'd be moving the bumpers off of the frame perimeter, or expanding the frame perimeter. This would result in gaps in the bumpers' coverage of the frame perimeter, or a violation of mounting rules.
In other words, if the rules don't change on mounting, you're going to be in trouble with the perimeter coverage rules. This is some of what Duke was getting at--<R07-A> in the 2011 rules.
Unread 28-11-2011, 22:27
Andrew Lawrence
Posts: n/a
Me neither, but it's probably possible. I can think of a few ways, but they would be way too advanced. There are other, simpler ways, but I don't know. Just thinking, that's all.
Unread 28-11-2011, 22:29
Duke461's Avatar
Boiler Strong.
AKA: Ben Carson
Yeah i definitely like the concept.
Maybe you could do what the dragonfly robot did, and then on top of that, those appendages could shoot out with pneumatics. That would be awesome.
Unread 28-11-2011, 22:36
Andrew Lawrence
Posts: n/a
I like that, but the goal is to avoid hitting opponents above the bumper line. That's why I had the bumpers move, for more bumper on bumper action, and less robot on other robot killing second robot and disqualifying first robot action, if you know what I mean.
Unread 28-11-2011, 22:39
Duke461's Avatar
Boiler Strong.
AKA: Ben Carson
They wouldn't hit above the bumper line. The bumpers, as 3553 did, would be on the ground flush with the real bumpers. Youd simply need some kind of linear slide on the appendages, and the pneumatics would shoot it straight out into the opponents bumper.
Unread 28-11-2011, 22:41
Andrew Lawrence
Posts: n/a
I see. I like that! Thanks!
Unread 28-11-2011, 22:52
I would be VERY cautious with using a drop-down active bumper system. If someone tips over while it's active next to them, you're probably going to get warned, possibly carded and penalized. Also, bear in mind the expansion rules, and that you're putting extra weight in there that could probably be better spent elsewhere.
Just some things to keep in mind.
You *might* be able to pull your first option off within the rules, but the "rigid mounting" might get you, at least last year it would have.
Unread 28-11-2011, 22:57
Andrew Lawrence
Posts: n/a
I probably should have said this at first, but unless the game next year and manuel give us a distinct advantage, I doubt I'll ever be using it. I just had the idea, and wanted CD's input. From what I'm hearing, the 1st option may be viable, so I'll test that on my own time.
Thanks everyone!
Unread 28-11-2011, 23:16
Thanks everyone!
"Viable" is rather loosely used here, IMO. Under last year's rules, specifically <R07-K>, you'd also need to have the frame perimeter movable to have movable bumpers; that could make life rather "entertaining" with other stuff that needed to attach in that area. You'd also want to pay attention to the pneumatics rules.
Unread 28-11-2011, 23:19
Andrew Lawrence
Posts: n/a
Well, I do enjoy "entertaining"!
Unread 29-11-2011, 07:20
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
From the 2011 FRC Manual
K. BUMPERS must attach to the FRAME PERIMETER of the ROBOT with a rigid fastening system to form a tight, robust connection to the main structure/frame (e.g. not attached with Velcro). The attachment system must be designed to withstand vigorous game play. All removable fasteners (e.g. bolts, locking pins, pip-pins, etc.) will be considered part of the BUMPERS.
A movable bumper in not rigidly mounted.
"Dragonfly" got around this rule because technically their additional drop down bumpers were non-functional decorations, not bumpers.
Thank-you 294 & 67
www.bobcatrobotics.org
