Go to Post I am a human wiring diagram, how can i help you? - Jeffy [more]
Unread 30-11-2011, 07:50
Ross3098's Avatar
Ross3098 Ross3098 is offline
Programmer
AKA: Colin Ross
FRC #3098 (The Captains)
Ross3098 will become famous soon enoughRoss3098 will become famous soon enough
Robot Not Recieving Code
Ive recently brought the robot out of the garage in a sense and wanted to start tinkering with it. I downloaded the latest windriver update on FIRSTforge and reimaged the cRIO for image v30. I downloaded code to the robot and it recieved the code, but I accidently downloaded an empty project so it wasnt able to do anything. I then set the downloader to the right code to download and used the deploy button to download. It undeployed and deployed like it should. After I rebooted the robot there was no robot code.
Anyone know how to fix this problem I can't think of anything I did wrong in setting this up.
2012 FRC Championship: 4th pick, Quarterfinalist: Thanks 1507, 51!
2012 Michigan State Championship: 4th Seed, 3rd Alliance Captain, Semifinalist: Thanks 33 and 2137!
2012 Northville District: 3rd Pick, Quarterfinalist. Thanks 302, 4405!
2012 Waterford District: 2nd Pick, Finalist. Thanks 573, 3601!
2011 Waterford District: 8th seed, 1st pick, Semi Finalist. Thanks to 573 and 3770
2011 Ann Arbor District: 2nd seed, Finalist. Thanks to 548 and 247.
2011 Michigan State Championship: Semi Finalist. Thanks to 548 (Again) and 74.
2011 FIRST World Championship: 8th seed, Quarterfinalist. Thanks to 74(Again) and 846.
Unread 30-11-2011, 09:18
Re: Robot Not Recieving Code
Use netconsole to see where your code is immediately dying.
I haven't seen v30 for the cRIO, so I'll have to go looking for that.
Unread 30-11-2011, 11:28
It's in the offseason updates that fix the encoder rate problem. http://firstforge.wpi.edu/sf/frs/do/...1_0_for_2011_f and http://firstforge.wpi.edu/sf/frs/do/...ate_for_2011_f
Unread 30-11-2011, 12:52
Ross3098's Avatar
Programmer
AKA: Colin Ross
Could you tell me how to set up netconsole?
Sorry I've never had this problem so I've never had to use it.
Unread 30-11-2011, 14:45
The cRIO gets setup for NetConsole by a selection in the cRIO Imaging Tool
  • Enable NetConsole
NetConsole on your PC gets installed as part of the FRC Utilities package. You should find it on your Windows Programs list, it'll be listed as NetConsole for cRIO.
Make sure your PC netmask on the connection you're using is set to 255.0.0.0, because NetConsole broadcasts.
Unread 17-12-2011, 14:55
calcmogul's Avatar
calcmogul calcmogul is offline
WPILib Developer
AKA: Tyler Veness
FRC #3512 (Spartatroniks)
calcmogul is just really nicecalcmogul is just really nicecalcmogul is just really nicecalcmogul is just really nice
My team just recently had this problem and solved it. Our code was being deleted after a power cycle because some functions weren't overridden in the C++ robot code. The RobotInit() virtual function was causing our problem. The cRIO outputted these functions to a console, like NetConsole, when overriding was required with a message similar to "RobotInit(): override me!".
