My crate or yours?
Go Back   Chief Delphi > Announcements
Thread Tools Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Unread 25-11-2011, 20:44
BJT's Avatar
BJT BJT is offline
uh, should that be smoking?
AKA: Ben Thorsgard
FRC #0876 (Thunder Robotics)
BJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond reputeBJT has a reputation beyond repute
Re: Battery Beak
I'll buy one as soon as you shrink the picture and stop squishing the rest of the portal page. Seriously, I will
2016 Central Illinois Winner. Curie Division finalist
Unread 26-11-2011, 10:28
DonRotolo's Avatar
OMGweek5whyarentwedoneyet OMGgetgoin
FRC #0832
Re: Battery Beak
The web site states that it uses internal resistance.
The auto industry has been using internal resistance for battery health (but not state of charge) for many years. In general, the higher the internal resistance, the worse the condition of the battery. You must properly characterize the battery (chemistry, capacity) for this to work properly.
The screen display shows three voltage readings at different current values, I speculate that this is used in addition to internal resistance to measure battery condition. This is an even older (and some say more accurate) method for battery condition. In the auto industry, it is (or was) common to have a carbon pile load to test batteries, rule of thumb was 3x the Ah rating in amps, check the voltage at 15 seconds.
I will also speculate that state of charge is calculated by measuring open circuit voltage after a small load (like 18A for 10 seconds) is used to remove any possible surface charge.
Assuming the designer knew what she was doing, using these three methods (none of which are technically challenging) should produce repeatable results that are accurate enough for our purposes.
Unread 26-11-2011, 14:19
Brandon Martus's Avatar Unsung FIRST Hero
Brandon Martus Brandon Martus is offline
busy.
AKA: B. Slash Kamen
Brandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond reputeBrandon Martus has a reputation beyond repute
Send a message via ICQ to Brandon Martus Send a message via AIM to Brandon Martus Send a message via Yahoo to Brandon Martus
Re: Battery Beak
haha .. that was my fault. i'll fix it.
Brandon Martus
e-mail
Unread 27-11-2011, 02:53
BJT's Avatar
BJT BJT is offline
AKA: Ben Thorsgard
Re: Battery Beak
Sweet, I just ordered one, thanks
Unread 30-11-2011, 17:55
Re: Battery Beak
I've found that I need the Large Print screen version
Works nicely. We'll run comparisons of the Battery Beak results against the battery test plots at our next meeting.
Unread 30-11-2011, 18:46
Mike Copioli's Avatar
Mike Copioli Mike Copioli is offline
You make it pretty We make it dance
no team (Retired(3539, 217))
Mike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond reputeMike Copioli has a reputation beyond repute
Re: Battery Beak
The Battery Beak User Manual is now up at: http://www.crosstheroadelectronics.com/Beak.html. Please let me know if there are any typos, errors or problems with the link.
Mike Copioli
CTRE Hardware Engineer
http://www.ctr-electronics.com
Team 3539 The Byting Bull Dogs
2013 Michigan State Champions
Team 217 The Thunder Chickens
2006 World Champions
2008 World Champions
2009 Michigan State Champions
Unread 30-11-2011, 19:53
Re: Battery Beak
Here is a good battery/bad battery comparison (actual size on my screen resolution).
The third one is the good battery fresh off a charger (now rated only Fair)
The bad battery's measured badness matches our team number.
Take this bad battery with a grain of salt, I have another one in mind to test with that I've already independently measured the internal resistance of.
Unread 30-11-2011, 20:34
Re: Battery Beak
Originally Posted by Mark McLeod View Post
The bad battery's measured badness matches our team number. ]
This makes me laugh.
[/quote]
Mark,
The first battery on the left, the one that measured as bad is discharged, Charge the battery and then perform the test again. The last battery that measured fair looks like it was just pulled off of the charger, you should let it rest for about 15 minutes to an hour to allow the surface charge to penetrate the plates. You should see about a 10% decrease in the internal resistance after this.
Mike Copioli
Unread 30-11-2011, 20:56
Re: Battery Beak
These are only batteries that I happen to have at home (Well I do have more bad batteries here, but I'm not really interested in testing obviously bad batteries except for what help it can lend on team visits).
I'll do more extensive variations when I get to the shop.
Nope, that bad battery is as fully charged as it will go
It really is a bad battery. It came from the recycle pile.
Understood, someone PMed a question about what it looked like if (incorrectly) tested with a surface charge, as in rapid pit battery changes with the batteries fresh off a charger.
The middle and right are the same battery after 10 minutes on a charger.
.026 (no surface charge) to .029 (with a surface charge) is the 10% difference you mention.
I'm waiting for the surface charge to dissipate again now to see if the resistance drops and the Beak returns to a Good rating.
Unread 30-11-2011, 23:48
Re: Battery Beak
For a moment I thought the Battery Beak would actually quantify a battery's "badness" and was brought back to the days of writing in LaTeX and getting "Badness: 10000" errors.
Mike, could you add a badness rating? Please?
Unread 02-12-2011, 21:32
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Re: Battery Beak
That was my comment when Mike showed it to me at IRI. Al Skierkiewicz was nearby, and he had the same comment.
What do he and I and Mark have in common, hmmm ....?
Anyway, I ordered one on Tuesday and it arrived this morning. I'm hoping it will help my new team manage batteries better this year. It won't really matter if my old eyes can read the tiny screen -- the student who is responsible for battery charging will be recording the data, not I.
Richard Wallace
since 2003
Unread 02-12-2011, 21:52
Re: Battery Beak
We're each interested in the big picture?
Unread 03-12-2011, 07:41
Re: Battery Beak
Duly noted.
Mike Copioli
Unread 03-12-2011, 10:50
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
FRC #2641 (PCCR; Refs & RIs)
Re: Battery Beak
So just to make sure I understand, if I use the Beak on a battery I just finished charging in the pit, the Good ones will read "Fair" because of the higher Rint? (Do Fair batteries read "Bad"? Bad ones still read "Bad"?)
What's the minimum percent Charge that still indicates a surface charge to you (somewhere between 130% and 113%, I take it)? Is surface charge ok in actual use of the battery?
Thanks! I suspect these are stupid questions to anyone with a modicum of practical EE knowledge, but I regret I'm not really one of those people. I do need to fix this.
Unread 03-12-2011, 11:09
Re: Battery Beak
Don't do that. The results will be unpredictable.
Yes, assuming the battery is healthy and the surface charge is not fooling you into thinking the battery is good.
They are not stupid questions. They are important questions.
