#16
Re: Best defensive strategies
Is that really a defensive robot, or an extraordinarily good offensive bot? I guess it can be considered both?
#17
I think these two phrases represent 469 in 2010. I just love that design! Plus, if assisted correctly from alliances, it's possible to have all of the balls in your front zone, creating the perfect starvation tactic! I LOVE IT! ![]() |
#18
By that definition, it does technically prevent the other team from scoring, due to the scorable items, or lack thereof created. So, in a sense, yes, it is defensive. Though I agree with Hallry and SuperNerd256: 469's bot was just extraordinarily amazing.
#19
Ex: Red scored 20 and Blue scored 17 with all robots attemping to score. In the next match Blue places its weakest robot which only contributed 2 points in the previous match on Red's strongest scorer which scored 10 of the points in the previous match. In this match all of the other robots contributed similarly except the weakest Blue robot which scored no points (-2 because it did not score the two points it normally does) However, the strong Red robot was only able to score 4 points as a result of Blue's defense (+6 for the Blue alliance because Red scored 6 points less then it otherwise would have been able to.) This resulted in a match 20-6=14 to 17-2=15 Now the Blue team wins as a result of smart defense. I hope this kind of shows how defense can be a smart play. A very important note with defense is that when your alliance is deciding how to play you must make sure you maintain your offensive power. Basically in order to make defense effective, your alliance still must put up points. On the same note, if the defense being played is ineffective, then you are putting your self in a loosing situation. Ex: Using the same example above, if the weaker Blue robot can only hold the strong Red robot to scoring 8 points instead of ten (+2 for Blue's defense and -2 for lack of offense) there is a net gain of 0 points and the defense was unwarrented. Using a different deffensive method, the weak blue robot now pushes all tubes on the opponents side of the field into the lanes. This affects all three of the opponent's robots negitively. Lets say strong Red was fast and still able to put up 8/10 points. However, the other two Red robots were less able to cope and put up only a combined 6/10. This results in Blue's -2 for lack of offense. However, Red scored only 8+6=12 out of 20. 6 less then they normally would (+6 for Blue). Now the score is 20-6=14 to 17-2=15 again a win for Blue using smart Defense. In conclusion, Defense (and Offense) are all about maximizing your "net score." Because of this, finding effective ways to defend using minimal effort while still recieving results is key to success in any FRC match. This is a really interesting topic, defense is definatly more then just hitting people. Regards, Bryan Edit: 469's 2010 robot played "Before" defense. preventing the opponents from being able to aquire game objects in order to score them. However, they were able to do this while also scoring at the same time. Because of this their "net score" was doubly effected. Not only were they scoring 10+ a game but they were recycling 3+ balls that the other team couldn't score with and usually drawing a defender to play "ping pong" which was a another loss of points for the opposing alliance. Last edited by BJC : 30-11-2011 at 23:34. |
#20
That slider was TOUGH to get around. Here's one of my favorite pictures from 2004. It's our robot (team 11) hanging on the claw mechanism of 237. It didn't count as a hang because werent being fully supported by the bar, but the battle to even get in that position was epic. -Brando ![]() |
#21
Oh, and it was only tough to get around them if you were slow getting onto the bar (AKA, not a bar blocker). 330 forced them to play defense on the ground in Archimedes on at least one occasion. |
