Go to Post SELECT YOUR STRATEGY BEFORE YOUR ROBOT DESIGN. - Kims Robot [more]
Unread 19-11-2011, 07:47
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
Re: pic: Off season teaser 1
In all this project was initially started as a swerve project but to reduce weight and cost of a traditional swerve/crab drive it took some designs from a car (ackerman steering). It isn't a true swerve/crab drive nor is it a true ackerman steering drive but somewhat of a hybrid for the sake of using less funds and weight.
461 Westside Boiler Invasion
45 Technokats
Unread 19-11-2011, 12:27
FRC #1836 (MilkenKnights)
There are a couple of problems with this design:
1) Compwiztobe is right; the miter gears will lock
2) If you try to turn this assembly, the wheels will try turn in opposite directions (think of a 2 wheel drive turning) and something will have to brake or slip.
3) (i'm assuming you are going to use two of these modules) When all the wheels are collinear, the robot will fall over. If you add casters though, you can fix this problem, but that defeats the point of make two wheel modules in the first place.
4) You won't be able to turn, because unlike regular swerve, you do not have the 4 modules to form a x with the "turn' chain. You could potentially add caster, but again, that defeats the point of making modules with two wheels.
Sorry for being so negative. On the bright side, this is the dedication that makes teams win. Nice job trying to reduce the price, weight, and complication of arguable the best drive train in first.
Unread 19-11-2011, 12:41
Sorry, I didn't realize what the pink sprockets were there for, so you can disregard comments 2 and 3. Just another comment, you will be limited in your strafing, specifically in strafes exactly left and right, or near those angles. This is countered though, by your easily achieved Ackerman steering, that needs very little programming. After my little revelation, I have realized that this is actually a rather viable drive train, once comment 1 has been fixed, to allow teams with very little resources and time, to achieve a drive train that acts like 6 wheels swerve, without the ability to strafe perpendicular the the robot, and to turn on the spot, like swerve and 6 wheel. With improvements, this could become something a lot like octocanum, giveing close to the best of both worlds.
Unread 19-11-2011, 13:26
With the miter gears, I wouldn't be surprised in the least if the bottom one was free-spinning. It's set up so that that's all you'd need to do to keep the gears from locking up. Then you just have one gear acting as a spacer.
Unread 19-11-2011, 22:29
45 Alumni
AKA: Peyton Yeung
1. Like EricH said, the bottom one is a spacer.
2. The wheels turn together so they always face the same direction.
3. There is no possible way for all 4 wheels to be on the same line.
4. Isn't it possible to turn a four wheel drive bot by giving a positive value to 1 set of wheels and a negative value to the other set of wheels?
The fronts are linked together and the backs are linked together.
45 Technokats
Unread 20-11-2011, 10:19
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
Awwwww I was looking for the new ball drive.
But it looks really good! I would also like to see how it interfaces with the frame and such.
Unread 20-11-2011, 10:46
Like I said, disregard 2 and 3. For number 4, if you look at the CAD, the supershifter will be connected to both wheels. This means that you cannot power each side individually, so you cannot turn like a 6 wheel.
Unread 20-11-2011, 14:45
If you have 2 of these, each side is powered independently. If they're front and back, as stated, then it's a wide-oriented 4WD. Turns quite well, actually--maybe better than a 6WD.
There just haven't exactly been all that many wide-oriented robots the last few years--2009 had quite a few, though.
Unread 04-12-2011, 08:49
CNettles11's Avatar
CNettles11 CNettles11 is offline
AKA: Chris Nettles
FRC #3502 (Octo-Pi-Rates)
CNettles11 is a jewel in the roughCNettles11 is a jewel in the roughCNettles11 is a jewel in the roughCNettles11 is a jewel in the rough
I hate to revive old threads but, this is a steering solution that will work, and this is how.
Last edited by CNettles11 : 04-12-2011 at 08:58. Reason: I had to fix the diagram.
Unread 04-12-2011, 08:55
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
On that last diagram, the bottom arrow is reversed, right? Or does this have mecanum wheels capable of that kind of translation?
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 04-12-2011, 08:57
CNettles11's Avatar
AKA: Chris Nettles
That was definitely me slipping up, I should fix that.
Unread 04-12-2011, 20:56
but you still cannot turn on a dime
Unread 04-12-2011, 21:52
Andrew Lawrence
Posts: n/a
If you have your code set up so as that you can align all wheels straightly, you can turn with a skid-steer system. I wonder if that's even more possible with a 6 wheel drop center swerve...
Unread 04-12-2011, 21:55
Not with this setup, as left and right wheels are driven together.
Unread 04-12-2011, 23:28
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
Per an earlier post:
If you have 2 of these, each side is powered independently. If they're front and back, as stated, then it's a wide-oriented 4WD. Turns quite well, actually--maybe better than a six wheel drive
If the pair of wheels in each of these assemblies is aligned (i.e. They're perpendicular to how the original picture shows them) it will allow the robot to function as a four wheel tank drive, which can turn just fine.
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
