Go to Post The 3 probably stands for the number of years this season will take off your life - JohnSchneider [more]
Unread 06-12-2011, 09:10
Cem8301's Avatar
Cem8301 Cem8301 is offline
Carolyn
AKA: student president
FRC #3413 (Mad Cows)
Cem8301 is an unknown quantity at this point
Tips on Improving Robot Design
This is an off season project my team has nearly finished. It has served at a great learning tool for new students/ a first time test for pneumatics and Solidworks for the team. Any suggestions for improvements? - Besides that the pneumatic piston is still ductaped to the arm and the manipulator wheels are not yet powered? Any and all critiques are welcome!!
Some specs: We used 1/16" thick, 1" square aluminum tubes, rivets, and various brackets for build. The lift for the arm is powered by a banebots motor and FP gear box. This system is currently attached to a rod via pin to the rod (rod subject to bending...). The manipulator wheels will be powered with a Vex motor.
The steaks are high. Prepare for udder destruction!! <3 Mad 3:O's
Unread 06-12-2011, 09:37
Andrew Lawrence
Posts: n/a
Re: Tips on Improving Robot Design
Just my opinion, but GET THE MECANUM WHEELS OFF!
I know the omnidirectional drive is cool, and looks promising, Any standard tank drive system will easily push you all match long. I think mecanums are cool for any purpose other than competition. Do you know how many mecanums usually make it to Einstein? As far as I know, none. Any team with mecanums are not only easily pushed, but are generally easily defended against, which, while game pending, is never a fun thing.
I think mecanums are just a waste of weight, and drivetrain, so that is my advice to you.
EDIT: Also, it looks a little back heavy. How's the weight balance working out for you?
Unread 06-12-2011, 10:00
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
For this game, how much pushing around was there, really? We had mecanums and didn't regret it. In fact, they came in handy when in the safe zone, positioning for the score.
In a game like Aim High or Rack N Roll, I'd totally agree with you. But here, mecanums were a viable option. Plus, it's an offseason project. What better time to explore drivetrain options to see if they're a fit for your team or not?
Hi!
Unread 06-12-2011, 10:32
Joining the 900 Meme Team
FRC #0079
I'll come out and say it, I like it. Yeah, it isn't pretty and by the sounds of it has some flaws but I like that you took the time to build an entire robot in the off season. Now the $5 million question, what did you learn?
Like all things in engineering there are tradeoffs between this drive system and others. If not being pushed is important to you but moving sideways is not then you must take that into account. It depends on what your strategy is.
Unread 06-12-2011, 11:27
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Great job, use it, abuse it, and see what breaks. If you want to give the programming team a challenge, add a gyro and have them test field-oriented driving.
Don't be so down on mecanums, especially for learning. Using that robot as a test bed, you can easily swap the four wheels and experiment with traction wheels, omni wheels, mix of the two, etc.
Mecanums are also a good choice for a demonstration robot for fundraisers and sponsor presentations. Easy on the carpeting, and maneuverable in small spaces.
The more teams experiment with mecanums, the more you will see ingenious solutions for pushing.
Unread 06-12-2011, 12:00
It's the offseason. Leave them on.
If you experiment with them in the offseason, then when the season rolls around and you build your competition robot, if (and this is a big if) the mecanum drivetrain turns out to be advantageous, you already know how to use it. If it doesn't, it's not that hard to turn a mecanum system into a 4WD system and practice with it.
Unread 06-12-2011, 12:17
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
It looks really nice. Integrating the actuation for the wrist into the 4-bar is very slick, however be wary of bending. I think when 148 did it this year they used a piston to push/pull sheet metal sliders. Basically the 4 bar was still very strong because the piston was not actually acting as a structral part of the arm. I would be concerned with the piston getting even slightly bent in a hard colision and no longer functioning properly.
Also, on your bell crank pivot down towards the bottom of your robot there is quite a lot of open shaft on either side of the arm. The further away that shaft is supported from the load the greater chance that it will bend. There is also the chance that it will begin to bend over time and continued use so it is probably worth supporting it closer in on either side so that can't happen. In any case, it is a good practice to support shafts close to the load as possible.
Overall it looks great! Looks like you are very ready for build season.
Regards, Bryan
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
Unread 06-12-2011, 12:41
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
The picture is a bit small, so it's hard to make out many details. The first thing that I saw that I'd change is how the pneumatic cylinder on the arm is mounted -- and I don't mean the duct tape.
Right now, when the cylinder rod extends, it is 'exposed' and any side loading on the end of the arm will get transferred back against the cylinder rod. A rough impact may bend your cylinder rod and then you're in a bad place since replacing the cylinder is expensive -- both in time and money.
It'd require a rework of the upper link of the arm, but consider sliding the cylinder back toward the upper pivot so that, when its rod is fully extended, it's still supported and protected by the fixed part of that arm. I suspect your design is inspired heavily by 148. Look more closely at that robot -- its CAD model is available here -- and consider carefully why they designed their extending upper link the way the did.
Forgive the derailment, but I see this getting parroted a lot these days and I'm not convinced it's a valid argument. Folks make it seem as if the only difference between a mecanum wheeled robot and 254 et al is the wheelset. That's absurd on its face.
So, let's have it -- in your opinion, which teams were capable of winning the Championship but, by deciding to use mecanum wheels, didn't make it?
--Madison--
...down at the Ozdust!
Unread 06-12-2011, 17:05
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
We used this logic in 2009 as a reason not to build a widebody robot, because so few had made it from 2001-2008. (IIRC Wildstang in 2001 & 2003 were the only examples we came up with)
Fast forward to Einstein that year 11 widebodies and 1 narrowbody (us). Our logic was flawed because this is really a game/strategy/field driven decision.
You shouldn't discount something just because it hasn't worked yet, if you do that you will never innovate and refine something that is close to working because you instantly call it a failure. There are too many influences besides drivetrain style that effect who makes Einstein, so don't mistake correlation with causation.
I have no doubt there will be a team that creates mechanum, drives it well as a mechanum and makes Einstein. (I just won't predict this year without seeing the field.)
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 06-12-2011, 17:16
Laaba 80 Laaba 80 is offline
AKA: Joey
FRC #1714 (MORE Robotics)
Laaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond reputeLaaba 80 has a reputation beyond repute
Try telling 525 that mecanums are bad.
http://www.thebluealliance.com/team/525
Driving Record - 75-43-8
Coaching Record - 92-65
Unread 06-12-2011, 18:40
avanboekel's Avatar
avanboekel avanboekel is offline
AKA: Adam Van Boekel
FRC #5934 (Gear it Forward, Crowbotics)
avanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant future
I agree, but here is not the place to be arguing mecanum vs tank.
It looks like most of your weight is on the back wheels. This may lead to problems because balance is extremely important for a mecanum drivetrain. Otherwise, great job. Its a very clean looking robot.
2338 Gear It Forward | Student 2010-2013 | Mentor 2014-Present | oswegofirst.org
2013 Wisconsin Regional Winner (1732, 111, 2338)
2013 Midwest Regional Dean's List Finalist
2015 Midwest Regional Chairman's Award Winner
2015 Archimedes Subdivision Winner (1023, 2338, 3996, 1089)
2016 Midwest Regional Chairman's Award Winner
4096 CTRL-Z | Mentor 2014 | team4096.org
5934 Crowbotics | Mentor 2016-Present | crowbotics.org
Unread 06-12-2011, 19:26
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
Make a y bracket and attach to frame to lock in the gripper when it is in the down position picking up a tube. In the event of a hit on the gripper from another robot the bracket will off load the forces from the upper axle down low to the floor preventing your arm from being bent.
Clean up and label your wiring. Invest in a crimper and some Molex connectors.
Keep the CG as low as possible and try to maintain a balance design.
When selecting your gearing try to use paired ratios in your transmissions so you can easily change gear ratios to make your mechanism slower/faster
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 06-12-2011, 19:40
Andrew Lawrence
Posts: n/a
Wow. I didn't expect this to derail the thread. We've had experience with mecanums, and it wasn't so good. I've seen a lot of unexperienced teams with a lot of potential use mecanums not knowing what to expect defensive-wise, and end up getting pushed around by the simplest of drive trains, disabling their ability to function. Just my opinion, that's all.
Let's not derail this thread further.
I agree with Roysturr. Adding a y bracket and attaching it to the frame would help a lot.
Unread 06-12-2011, 19:51
AlecMataloni AlecMataloni is offline
Excellence is Bliss
AlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond repute
http://www.chiefdelphi.com/forums/sh...9&postcount=11
These connectors I linked to in an earlier thread is incredibly useful for wiring. Many teams (including ours) have learned to love them. You should definitely consider using them in the future.
Unread 07-12-2011, 09:05
Cem8301's Avatar
Carolyn
Our robot has done a lot of sitting and slow driving around. So we haven't encountered any problems as of yet-- thanks for pointing that out! Also, thank you for pointing out other mecanum flaws. This will serve as sufficient motivation to work on CADing other drive trains!
Originally Posted by Andrew Schreiber View Post
what did you learn?
-I have learned that rivets are amazing and often better than bolts. (saves: weight, time re-tightening loosened bolts, and awkwardness of trying to hold wrenches at funny angles)
-That the robot manipulator should always have full control over the game piece// and be able to protect it when driving around. (did learn this from 148!)
-To look work on efficiency and look at the big picture. Our actual design from the Logomotion game could not pick tubes up off the ground.
-And of course, that planning a design in Solidworks avoids countless hours of frustration and re-fabrication.
All of your posts have been very helpful! I never thought of adding a y-bracket to protect the arm.
