Thread Tools |
Rating:
Display Modes |
Re: First Official 2012 Game Hint
Your opponent scored on you in 2006 (opposite of 2010). If you didn't clear the ball corral fast enough, the opponents score would keep going up.
Oh.... :\
There was a match replayed that year... in finals... because the lower goal counted 5 balls too many in automode. 4 high (12 points) versus 10 low (10 points), and 10 low won autonomous (score 15 points). Yes. This was in a regional finals match. The way the game was set up, this screwed up the entire match. After this incident and others like it, a delay to allow for the manual counters to report in was added.
It wasn't the hardware, IIRC, but the software that didn't quite work properly. |
Whoa...I think this is the most substantial game hint I've seen. Not a cryptic phrase or an obscure photograph, but a parts list for the field? In a plainly readable format?
This is too easy. It must be a decoy. The real game hint is obviously steganographically encoded in the image. Come on CD'ers, start cracking... |
#7
Could the "Very high speed" of the counter not refer to how many times it can count in a second but its response time to a change of input? I am not sure exactly how it works, but the high speed may just mean that whatever triggers the sensor (probably photogate) is only blocking the photogate for a short time, meaning that it is small and/or moving fast.
Even launching a few balls into a goal a second is "fast" from the game prospective, but is nothing for a computer (and the parts list had LAN adapters that enabled direct IO, I believe somebody posted.) There must be some reason for FIRST to add extra circuitry between the computer and the sensor. If the network is not fast enough to register a goal with whatever sensor it is, the adding of a "quantizing" counter between them would eliminate this problem. People said that in Aim High the counters were unreliable, does anyone know why? was it a speed-of-signal-pulse issue? If used like this, this part seems like it would probably have been inserted as a tweak as the GDC played and tested (and figured that it wouldn't work well without it). I can see it happening. photogate input: . . . . . . . . . . . . . . . . . . . ._____/\__________ Time the network is looking for a response (when high): ----____----____- it would not be recorded because the pulse happens when the network is not listening with the "quantizer" photogate input: . . . . . . . . . . . . . . . . . . . ._____/\__________ signal to network: . . . . . . . . . . . . . . . . . . ._____/----\______ Time the network is looking for a response (when high): ----____----____- this time the signal and the async time the network is "looking" line up, so there will be a score detected. |
#8
I had an idea:
what if the high speed sensors are used to monitor robots driving though lanes? like a 1-robot-per-lane version of overdrive? just a thought... |
#9
It would be hard to drive through a lane that was wide enough for only one robot to drive through and long... It was fairly hard to squeeze through in between the tower and the perimeter last year, and that was slightly wider than 1 robot wide, and very narrow...
#10
Correct me if I am wrong Gary. Quote:
Like above, never was able to view the 2006 goals even with the internet searches these days. I was just stating that in 2010 there was a certain bottle neck that the balls could eventually go through one by one counting each separately mainly referring to the fact that game pieces will most likely be scored one by one. |
#11
I'm curious to how long RSLogix has been used by FIRST HQ. |
#12
Incidentally, being frequently used in industry is not a sufficient reason to encourage teams to try something. Industry does lots of inefficient, uneconomical or otherwise illogical things because it has constraints that don't apply to teams or students learning engineering methods. Furthermore, assuming a finite amount of time to learn industrial techniques, it's not necessarily a good idea to split efforts between platforms. |
#13
