Go to Post The GDC made something easier??? Link or it didn't happen! - JesseK [more]
Go Back   Chief Delphi > FIRST > Rumor Mill
Thread Tools Rating: Thread Rating: 14 votes, 5.00 average. Display Modes
Unread 06-12-2011, 23:06
bhaidet's Avatar
bhaidet bhaidet is offline
FRC #0435
bhaidet is an unknown quantity at this point
Re: First Official 2012 Game Hint
Could the "Very high speed" of the counter not refer to how many times it can count in a second but its response time to a change of input? I am not sure exactly how it works, but the high speed may just mean that whatever triggers the sensor (probably photogate) is only blocking the photogate for a short time, meaning that it is small and/or moving fast.
Even launching a few balls into a goal a second is "fast" from the game prospective, but is nothing for a computer (and the parts list had LAN adapters that enabled direct IO, I believe somebody posted.) There must be some reason for FIRST to add extra circuitry between the computer and the sensor. If the network is not fast enough to register a goal with whatever sensor it is, the adding of a "quantizing" counter between them would eliminate this problem.
People said that in Aim High the counters were unreliable, does anyone know why? was it a speed-of-signal-pulse issue?
If used like this, this part seems like it would probably have been inserted as a tweak as the GDC played and tested (and figured that it wouldn't work well without it). I can see it happening.
photogate input: . . . . . . . . . . . . . . . . . . . ._____/\__________
Time the network is looking for a response (when high): ----____----____-
it would not be recorded because the pulse happens when the network is not listening
with the "quantizer"
signal to network: . . . . . . . . . . . . . . . . . . ._____/----\______
this time the signal and the async time the network is "looking" line up, so there will be a score detected.
