Go to Post Kickoff features the joys of discovery. Ship date features the fear of utter failure. - Koko Ed [more]
Unread 03-12-2011, 14:36
Stonemotmot Stonemotmot is offline
FRC #0486
Stonemotmot is an unknown quantity at this point
Using a variable as a class object in Windriver/C++
Hello, I am currently working on streamlining our teams code and was wondering if it is possible to use a variable to reference a specific object.
For Example
Say I named a solenoid object 1 and had a int variable named b that stored 1 could i say
b.Set(true) and have the same result as 1.Set(True)
If it cannot be done this way is there another way to get the same result. The key to what I want is to have a numeric value that relates to a specific object.
Thanks for any help in advance.
Unread 03-12-2011, 16:15
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
Re: Using a variable as a class object in Windriver/C++
Try a map.
#include <map>
map<int, Solenoid*> solenoids;
solenoids[1] = new Solenoid(1);
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 03-12-2011, 20:25
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
A map is the only way to "map" (hint hint nudge nudge) integer values to solenoid references.
Attending: MN Duluth Regional
Unread 04-12-2011, 00:05
WizenedEE's Avatar
AKA: Adam
FRC #3238 (Cyborg Ferrets)
Why doesn't an array work?
Solenoid* solenoids[3];
solenoid[0] = new Solenoid(5);
Unread 04-12-2011, 01:03
WPI Freshman
AKA: Alex
It does, at the penalty of having a fixed number of spots with fixed names to map to unless additional code is written.
To be clear, I was referring to the data type map, not necessarily the c++ implementation. I can count at least 8 ways in C++ to implement the map with varying degrees of effectiveness, map and hash_map (assuming that library is included in Windriver by default) being the most flexible with mapping names.
Point being, the map structure could accept any valid integer and associate the corresponding solenoid with it; with an array, you are forced to associate a solenoid with a specific value from 0 to size - 1.
Unread 04-12-2011, 04:14
Use an array. The amount of solenoids you have is known, so the associative array (map) doesn't add any value.
Unread 04-12-2011, 12:36
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Many people are answering your question, but no one has asked why you want to do this. Generally numbers are a poor way to refer to things. Especially if the numbers are arbitrary (don't have any meaning in the mechanism you are controlling).
The best generic way to do this is to simply name variables or pointers for each mechanism and use those to refer to the solenoids or anything else.
Such as:
Solenoid *leftGripper = new Solenoid(2);
Solenoid *impaler = new Solenoid(3);
impaler->Set(true);
or
class MyRobot : public IterativeRobot
Solenoid leftGripper;
Solenoid impaler;
	MyRobot() :
		leftGripper(2),
		impaler(3)
	void AutonomousInit(void)
		impaler.Set(true);
Do you have some compelling reason not to refer to each object directly?
Unread 05-12-2011, 20:46
WizenedEE's Avatar
AKA: Adam
Last year, we wanted to program the robot to set all the solenoids on to power the line tracking sensors. We just looped through each of the ports (it was in labview though).
Unread 06-12-2011, 01:37
WPI Freshman
AKA: Alex
Well, if you had an array of solenoid pointers for this, it'd just be something simple as having:
for(int solenoidPort = 0; 0 < 8; solenoidPort++){
solenoids[solenoidPort]->set(true);
Unread 07-12-2011, 14:32
FRC #0486
Thanks for all the imput. I was wondering if any of you could elaborate on how to implement a solenoid array.
Unread 07-12-2011, 14:50
See WizenedEE's first reply. I think we could provide more useful feedback if you could post your team's code.
Team 973 (2016-???)
日本語でOK
Unread 07-12-2011, 18:16
I'm don't really know C++, so I'm not sure if it is accessible, but SolenoidBase has a set which takes a value and mask and writes the whole module at once. For something simple like your use case, I would do something like that (value 0xFF, mask 0xFF).
However, trying to do something like that to for anything less trivial would greatly trade readability and maintainability for compactness, which for FIRST is not something I would try to do.
