Go to Post *referring to Team Titanium's 2012 robot* If only it could play guitar hero at the same time. sigh. - rsisk [more]
Unread 07-12-2011, 20:29
Any Mouse's Avatar
Any Mouse Any Mouse is offline
FRC #3145 (TeraViks)
Any Mouse is an unknown quantity at this point
Press Enter to Add One
I am new to c++ programing and am want to make a program in which if you press enter a number will increase by one. I can make the doesprogram loop and recognize 'enter', but when I try to put them together it doesn't work. Please help.
Unread 07-12-2011, 20:46
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
Re: Press Enter to Add One
Try something like this:
//make sure you #include <iostream>
int count = 0; //variable to store count
while(count < 10){ //this will only run 10 times
    system("pause"); //wait for user to press enter - this will send the Windows shell command "pause", and wait for the user to press enter
    count++; //increment count
    std::cout << "Count: " << count << endl; //show count to user
You'll need a variable to store the running count, and after the user presses enter, it'll have to be incremented. Does that snippet make sense logically?
Last edited by plnyyanks : 07-12-2011 at 21:47. Reason: forgot "std::" - good catch. or, put "using namespace std;" at the top of the program
Unread 07-12-2011, 20:56
Andrew Lawrence
Posts: n/a
Trust Phil. He knows this stuff.
Unread 07-12-2011, 21:18
plnyyanks's Avatar
AKA: Phil Lopreiato
Thanks Andrew, I try.
Unread 07-12-2011, 21:41
calcmogul's Avatar
calcmogul calcmogul is offline
WPILib Developer
AKA: Tyler Veness
FRC #3512 (Spartatroniks)
calcmogul is just really nicecalcmogul is just really nicecalcmogul is just really nicecalcmogul is just really nice
You can write this with a for loop too, which has variable incrementing built in:
#include <iostream> //has cout
for ( int count = 1 ; count <= 10 ; count++ ) {
    system("pause"); //waits for user to press enter
    std::cout << "Count: " << count << std::endl;
std:: needs to be added to the front of STL functions like cout unless you specify "using namespace std;" at the top of the program.
Unread 08-12-2011, 18:59
Any Mouse's Avatar
Thumbs up Re: Press Enter to Add One
Thanks that was very helpful.
