Go to Post But please take into account that each year, the GDC has to come up with a rule book that will spend the next three months being picked apart by 40,000 of the brightest, most creative minds on the planet. I think they do an outstanding job of it. - dtengineering [more]
Unread 08-12-2011, 09:55
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Re: Custom Vs. COTS Transmissions
Originally Posted by thefro526 View Post
We learned the hard way in 2011 that there's no 'easy' COTS solution for an arm transmission that requires a relatively high reduction. If we were to do it over again, we'd definitely build a custom box just so that we can avoid blowing half a dozen $70+ transmissions.
Really? We went completly COTS by putting AM fischer-to-Cim planetery into a 3 stage AM stacker box with a single sprocket reduction on the output. This solution was quicker and easier than building a custom gearbox to get the same redction. The use of the planeteries also gave use a more compact footprint than we would have ever had with a spur gear based transmission.
Thank-you 294 & 67
www.bobcatrobotics.org
