Go to Post You know it’s a tough game when you see a bearing on the floor. - D.Allred [more]
Unread 06-12-2011, 19:32
Sheik Rahaman Sheik Rahaman is offline
FRC #3748
Sheik Rahaman is an unknown quantity at this point
Autonomous help
We are new to using autonomous, and we were trying to load the default autonomous code on to our robot. however, it does not seem to be working. can anyone help?
Unread 06-12-2011, 19:42
Andrew Lawrence
Posts: n/a
Re: Autonomous help
When running your robot from the classmate, do you have it set to autonomous? There is a switch on the screen that lets you change between teleopperated mode, autonomous mode, and practice mode.
Unread 08-12-2011, 10:51
FRC #3748
Re: Autonomous help
Yes, i also enabled the code.
Unread 08-12-2011, 11:07
Re: Autonomous help
Which default code are you starting with?
You were given two choices with different default Autonomous(es).
  1. Robot Framework (Autonomous is disabled and must be enabled to do anything, but it's easiest to learn and work from)
  2. Robot Framework with Game Code (autonomous depends on specific line sensors being mounted on your robot)
Unread 08-12-2011, 17:10
FRC #3748
Re: Autonomous help
The framework without game code, the one that is disabled and has to be enabled.
Unread 08-12-2011, 18:34
Re: Autonomous help
  1. Open up Autonomous Independent.vi (under Team Code)
  2. Right-click on the edge of the disable box and choose: Remove Diagram Disable Structure
  3. Build and Run as Startup
PWM1 & 2 connect to your motor speed controllers
There are comments in Autonomous Independent.vi that tell you what it does.
Unread 12-12-2011, 21:31
FRC #3748
Re: Autonomous help
we had done just that, and autonomous still wasnt running
Unread 13-12-2011, 06:19
SuperS_5's Avatar
SuperS_5 SuperS_5 is offline
[Certified LabVIEW Developer]
FRC #1219
SuperS_5 will become famous soon enoughSuperS_5 will become famous soon enough
Re: Autonomous help
maybe take a screen shot of your autonomous code, and post it so we can take a look at it.
Mike B
