Go to Post I love robotics, it has a spot for every kinda future career a student chooses. - Bharat Nain [more]
Unread 07-12-2011, 15:24
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: 6 wheel swerves
Quick aside -- if 234's data is true then wider treads also make turning more difficult due to extra skid traction (if implemented across all 6 wheels).
GitHub
Unread 07-12-2011, 16:31
Dillon Carey's Avatar
Dillon Carey Dillon Carey is offline
6wd swerve, it has been done
AKA: TinyHippo
FRC #1625 (Winnovation)
Dillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond reputeDillon Carey has a reputation beyond repute
Re: 6 wheel swerves
Originally Posted by SuperNerd256 View Post
The only real implementation I can see is extra pushing power in all directions, which is in itself useful, depending on the robot.
The six wheel swerve actually had basically no extra pushing power past that which a four wheel swerve would have supplied. This is because it was a dropped center 6 wheel. Therefore it effectively only had four wheels on the ground at any given time.
The main plus to the 6wd swerve was maneuverability.
Our team has done a few 4 wheel "swerves" (people call different wheel configurations different names, so I will just group them all under the term "swerve"). We had always done 4 wheel swerves before, but didn't have the programming capability to create a swerve with independent steering and power for each module. without doing this a four wheel swerve will almost always lack the ability to rotate about itself well. (a notable exception is 1717's steering configuration)
In order to get past this dilemma without using programming, we decided to solve it mechanically, with the 6wd swerve.
"More power 'till it breaks or you win."
- Keith Carey
Unread 07-12-2011, 20:07
Re: 6 wheel swerves
For any math-oriented students who might be curious, here's1 the inverse kinematics for 6-wheel swerve.
I can't imagine any team actually wanting to build one like that, but who knows :-)
1look for "swerveN.pdf" near bottom of list
Last edited by Ether : 08-12-2011 at 01:06. Reason: corrected error in angle formula. my apologies.
Unread 08-12-2011, 09:31
Brandon Holley's Avatar
Re: 6 wheel swerves
While I'm not certain of the exact testing setup 234 has created and tested, we setup our own system.
I can verify that 4X2 won out in our setup as well.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 08-12-2011, 17:03
Best Available Data
FRC #1778 (Chill Out!)
Re: 6 wheel swerves
-Brando
Brandon/234/Aren,
Did you use a flat plate of tread of varying sizes or use actual wheels and some kind of load cell? Did you do both? It probably doesn't matter for the final result, I'm just curious how much of that increase is due to straight up surface area or if you get "bonus traction" due to the changing radius and interactions of the wheel/carpet interface under different loads.
Unread 08-12-2011, 19:01
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: 6 wheel swerves
No offense to 234/125, but until I can see the testing set-up, parameters, and data first hand I reserve my right to be skeptical.
Additionally, I'd like to see if they evaluated a greater quantity of wheels compared to wheel diameter. While I don't doubt there would be a correlation there, I'm curious if it's a 1:1 relationship. After all, this point did originate with having 6WD swerves providing more "pushing power."
Unread 08-12-2011, 19:03
Andrew Lawrence
Posts: n/a
Re: 6 wheel swerves
Ok. Now a new question for those who have used swerve:
Wild swerve, Revolution swerve, or custom swerve?
Unread 08-12-2011, 19:13
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
Re: 6 wheel swerves
We haven't implemented it yet but we have a design for a custom swerve. I feel like COTS swerve is less impressive than one that a team actually spent time designing, and adding their personal style to the design.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 08-12-2011, 20:33
Marc S.'s Avatar
Marc S. Marc S. is offline
Read the Manual! PLEASE!
AKA: Adversity
FRC #3925 (Robotics)
Marc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond repute
Re: 6 wheel swerves
If you know how to design or make it equally as effective than i would recommend making your own. If you try at it you will find some simple solutions in making it lighter and more suited to your design style.
However if you are not confident that you can make one then go with the revolution kit.
Alumnus FRC 973: 2010, 2011, 2012, 2013
2011 World Championship Winning Alliance Member
FLL Mentor and Competition Judge 2012-2015
Student-Mentor FRC 5102: 2014, 2015
Student-Mentor FRC 3925: 2015, 2016
FRC Ventura Regional Planning Committee Member & Regional Field Supervisor: 2015, 2016
Unread 08-12-2011, 21:40
Peyton Yeung's Avatar
Peyton Yeung Peyton Yeung is offline
45 Alumni
AKA: Peyton Yeung
Re: 6 wheel swerves
While this is our first year trying swerve, I would suggest staying away from a custom setup if you are new to swerve drives. If you try it make sure you have plenty of time to get it all up and working.
We are trying to create a custom swerve drive and it has taken quite a while to design and build what we have so far (not quite done yet).
Wild swerve is a little cheaper than revolutionary and both take less time than a custom setup to design because they are already designed.
461 Westside Boiler Invasion
45 Technokats
Unread 09-12-2011, 08:40
Re: 6 wheel swerves
That is indeed your right, and I too would be skeptical if the situations were reversed. Until we have our testing results in a more organized format, we're going to withhold them.
If I am understanding your second question, are you asking if we tested more than 1 wheel at a time?
About the testing setup- the wheels are mounted on a pivot arm, weight is applied at the end of the arm thus giving a standard "normal" force to any wheel placed in the rig. A torque wrench was utilized, and torque was applied to each wheel (each wheel being affixed to a shaft). We then recorded the torque each wheel experienced right up until it slipped. Pretty simple.
-Brando
Unread 09-12-2011, 09:00
Re: 6 wheel swerves
What precautions did you take to make sure the force on the torque wrench handle did not change the normal force?
Unread 09-12-2011, 09:24
Re: 6 wheel swerves
The torque wrench utilized a ~5" extension so that the physical handle of it hung off the edge of the table. We then had an aluminum block that had a pocket cut out of the top to accept the extension on the torque wrench. A top piece would then screw into the block to captivate the torque wrench extension. The entire torque wrench assembly would then be self-standing even when disconnected from the wheel testing rig. Due to various size wheels, we used this block in combination with a series of spacers to keep the extension on the torque wrench fully supported for all wheel sizes.
Unread 09-12-2011, 10:03
Re: 6 wheel swerves
I can't quite picture what you're describing. If the torque wrench handle is captured in a (stationary?) aluminum block, how do you push on it to exert a torque?
Do you have a picture of the fixture?
Unread 09-12-2011, 10:44
Re: 6 wheel swerves
I don't have a picture offhand, but can get one at our next meeting.
The block is supporting the extension of the torque wrench, not the handle itself. The handle remains free to rotate as it would normally.
The aluminum block is not acting as a clamp, more of a bushing. A loose enough fit that the wrench can spin, but snug enough to provide support to the extension. The block ensures the torque wrench is in the same position every time, and also ensures that the torque load is being exerted as axially as possible to the wheel.
PS: Maybe we should consider resurrecting/starting another thread as we've pretty much hijacked this one.
