Go to Post Dash Board: Hey Robot, here is some new data. Dash Board: Robot, did you get that data yet? Hello? Robot: Yep! Thanks! Yep! Thanks! Yep! Thanks! Yep! Thanks! Yep! Thanks! Yep! Thanks!... Other Robots: Will you please shut up? - EricVanWyk [more]
Go Back   Chief Delphi > Technical > CAD
Unread 09-12-2011, 18:30
marley4070's Avatar
marley4070 marley4070 is offline
The Guitar Kidd
FRC #2439 (Bearbotics)
Team Role: CAD
marley4070 is an unknown quantity at this point
CAD problems
Hey guys, I need help
I"m having a problem making holes in an angle that I'm working on in AutoCAD. I have poles set up where I want to create my holes, and I'll click on Subtract, click on my angle, then hit enter, but after I hit enter the commandline says "No solids, surfaces, or regions selected." Any help is much appreciated.
Thanks,
-Marley
Unread 12-12-2011, 09:55
JD Mather's Avatar
JD Mather JD Mather is offline
JD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the roughJD Mather is a jewel in the rough
Re: CAD problems
Attach the file here.
You must first extrude, revolve (or some other way) create a cylinder first before subtract
or
use Presspull of a circle.
Autodesk Inventor Certified Expert
Certified SolidWorks Professional
AU 2007 Avatech Altogether Smarter Inventor Challenge 1st Place
http://home.pct.edu/~jmather/content..._tutorials.htm
Unread 13-12-2011, 18:24
marley4070's Avatar
The Guitar Kidd
Team Role: CAD
Re: CAD problems
Thank you. I figured out the problem though. For some reason, I had to set the gizmo to no gizmo in order to make the holes.
Thank you though, JD Mather
-Marley
