Go to Post 15 thread derailment points - EmileH [more]
Unread 09-12-2011, 21:05
DavisC DavisC is offline
FRC #0539 (Titans)
DavisC is just really niceDavisC is just really niceDavisC is just really niceDavisC is just really nice
2 motor drive VS 4 motor drive
Recently my team is thinking about going from 4 motors on 2 gear boxes to 2 geared motors. Do think this is suffice for a good robot?
What are some of the more specifics on pros and cons of each?
Thanks
Unread 09-12-2011, 21:38
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
Re: 2 motor drive VS 4 motor drive
I've seen robots do it reasonably well. So it is sufficient.
I used the handy-dandy JVN design calculator to check, though. Without the extra motor, you increase the load on the remaining motor and halve your torque output without changing maximum speed. It still works, it just doesn't push as well.
That's good when you don't have to, or can't, push other robots. In 2009, additional torque was pretty much wasted on the slick floor; you'd just spin out the wheels. The weight of the motors was better used elsewhere that year.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Last edited by Ninja_Bait : 09-12-2011 at 21:52. Reason: I fixed the design calculator
Unread 09-12-2011, 22:06
the man's Avatar
the man the man is offline
AKA: Jacob Overla
FRC #4004
the man is on a distinguished road
Agreed.
Every day is a new adventure!!!
Unread 09-12-2011, 22:07
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
I guess we'll know in about a month, if it's a good idea or not.
Unread 09-12-2011, 22:17
The max speed changes somewhat. There is drivetrain friction and rolling friction. When you put all that load on one motor instead of two, the motor slides further down the speed vs torque curve.
Unread 09-12-2011, 22:28
John's Avatar
John John is offline
AKA: John Gillespie
FRC #1153 (Roborebels)
John is just really niceJohn is just really niceJohn is just really niceJohn is just really niceJohn is just really nice
Additionally, the acceleration of the robot will be cut approximately in half. This may or may not be a big deal depending on the game and what you are trying to do, but it could potentially make the difference between getting away from a defensive robot and them staying in front of you.
For 2009, many teams went with two motors because the low friction meant that any additional torque beyond what two CIMs provide would likely be wasted. Also, if you have a lighter robot the drop in acceleration may be less noticeable.
The obvious advantage to using only two CIMs in drive is allowing them to be used elsewhere. However, this past year the large number of other relatively high power motors (FP, 4 Banebots) made this much less important.
Unread 10-12-2011, 02:41
GRT808's Avatar
GRT808 GRT808 is offline
AKA: Grant
FRC #3008 (Kalani Falcons)
GRT808 is just really niceGRT808 is just really niceGRT808 is just really niceGRT808 is just really nice
Would a two motor drive do anything like significantly increase the risk of tripping a victor or jaguar?
Unread 10-12-2011, 03:02
Marc S.'s Avatar
Marc S. Marc S. is offline
Read the Manual! PLEASE!
AKA: Adversity
FRC #3925 (Robotics)
Marc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond repute
Yes, you could also take into consideration that the more motors you use, the less overall current draw you use. And all of your electronics will last longer.
Alumnus FRC 973: 2010, 2011, 2012, 2013
2011 World Championship Winning Alliance Member
FLL Mentor and Competition Judge 2012-2015
Student-Mentor FRC 5102: 2014, 2015
Student-Mentor FRC 3925: 2015, 2016
FRC Ventura Regional Planning Committee Member & Regional Field Supervisor: 2015, 2016
Unread 10-12-2011, 07:56
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
Possibly. The torque required to go from full forward to full reverse causes a current spike. With 2 motors that spike will be twice as high as with 4 motors. I have seen robots with high speed gearing trip the 40A breakers when doing this maneuver.
Mark
Brick walls are for other people. - Randy Pausch
Unread 10-12-2011, 08:52
Ninja_Bait's Avatar
AKA: Jake Potter
You can get these answers from the JVN calculator, too. The current draw does increase, though not necessarily to the point of tripping the breakers.
Sorry, yes, of course that's true. The calculator is a little ideal, so in the theoretical version the maximum RPM (and max speed) shouldn't be changed, it just takes longer to get there. In reality, though, there is speed loss, but it will probably be less dramatic than the torque loss.
Unread 10-12-2011, 09:27
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
We ran single CIM drives in 2006 and 2007.
From my experience with driving them, they were always grossly under-powered and rarely fast enough to catch another team while playing defense. If you run calculations on the drives you'll see that the math will agree with this. By the time you've geared a single CIM drive down enough to ensure proper loading on the motor, it won't be fast enough to catch much of anything.
IMO, running a single CIM drive in most games, Lunacy being the exception, is a good way to handicap yourself in competition.
-Dustin Benedict
Unread 10-12-2011, 10:38
Chris is me's Avatar
AKA: Pinecone
Engineering and math aside, try it. Build two kitbots, one with 2 motors and one with 4, and bring them both to weight.
Unread 10-12-2011, 12:10
Ninja_Bait's Avatar
AKA: Jake Potter
Because some teams drop the extra CIMs for weight, also test the two bots without extra weight to see if the weight reduction changes how our predictions play out. It's possible that the lighter version may still be a viable option, especially for low-weight robots. (I think it will get back some of the lost acceleration, but none of the pushing ability.)
Unread 10-12-2011, 12:44
the man's Avatar
AKA: Jacob Overla
FRC #4004
Depending on your wheels, and weight. The wheels may begin to slip at a certain point where two motors would not help with pushing power. Like lunacy. I think. Another thing to test for.
Unread 10-12-2011, 13:34
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Emphasis mine.
I think you meant to say "the less per-motor/controller current draw you will potentially use" because with 4 cims (4x40A breakers) it is possible to draw twice as much total current as 2 cims (2x40A breakers).
