Go to Post The imperfect COTS parts you have in your shop will perform much better on the competition field than the perfect custom parts you only have CAD drawings for. - philso [more]
Unread 13-12-2002, 19:02
Ken Leung's Avatar Unsung FIRST Hero
Ken Leung Ken Leung is offline
Dare to Live!
FRC #0115 (Monta Vista Robotics Team)
Ken Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond repute
Send a message via AIM to Ken Leung
Question parts as dead weight?
I got a pretty simple question about additional parts usage... And I am wondering if anyone can give me a quick reply...
May I use parts in the additional hardware list as weight on the robot? Things like shaft collar, bearings, nuts and bolts, gears, etc?
Hardware Test Engineer supporting RE<C, Google.
1999-2001: Team 192 Gunn Robotics Team
2001-2002: Team 100, 192, 258, 419
2002-2004: Western Region Robotics Forum, Score Keeper @ Sac, Az, SVR, SC, CE, IRI, CalGames
2003-2004, 2006-2007: California Robot Games Manager
2008: MC in training @ Sac, CalGames
2009: Master of Ceremony @ Sac, CalGames
2010: GA in training @ SVR, Sac.
2010-2011: Mechanical Mentor, Team 115 MVRT
Unread 13-12-2002, 19:15
FRC Key Volunteer Trainer
AKA: CrazyNate
Here's my thoughts on this...
as long as it's not a battery(see 2002 rule K9), and what you were using fell under the allowed parts, i wouldn't see a problem with it...however, if you're thinking about using a gear, why not just attach a block of material X(whatever gives you enough weight) to the robot?
Nate Smith
nsmith@smythsoft.com
Ed Sparks Ed Sparks is offline
Engineer/Mentor/Inspector
AKA: FirstCadLibrary Guy, Inspector Dude
FRC #3959 (Formally with FRC-34)
Ed Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond repute
Send a message via AIM to Ed Sparks Send a message via Yahoo to Ed Sparks
Sure .....
I know of no rule against this. In the past, I've seen aluminum and steel plate bolted on a frame to add weight. I suspect however that robot inspectors may have a problem with objects such as bolts and/or washers that are not fastened securely. In other words, a pile of loose parts that could dump onto the playing field is probably no good.
Ed Sparks
MECH TECH FRC-3959
Unread 13-12-2002, 21:11
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
Actually the term is ballast
I know that we have in the past added hardware that was legal (lead plate from SPI) but served no purpose other than moving the CG (Center of Gravity) of the robot.
Actually, it was amazing how a small shift could affect the handling of the robot.
Just be sure the material is tied down well, from a legal source, and either a kit part, a catalog part or on the additional hardware list. Since changing the CG affects the function of the robot, rules for non-functional materials do not apply.
Christopher H Husmann, PE
"Who is John Galt?"
Unread 13-12-2002, 21:38
Dare to Live!
Thanks! The question was answered within 13 mins. Yay! This forum really works.
My answer would've been:
The spirit of the additional hardware list is that you may use the allowed material/parts however you want, just like the raw materials. Keep in mind though, the 130 lbs rules still apply, and for specific parts like motors and batteries, you may only use the same number as how much you got from the kit on the robot.
So, you couldn't use like 5 drill motors or 15 innovation FIRST controller to add weight. .
You guys had some great answers, but I especially like how Nate specify which rule this is under in the manual. In terms of giving shot answers quickly, the first two answers by Ed and Nate was good enough for the asker to make some quick decision right away . I was also amazed that gross was the first one reading the question within a minute after it was posted.
I have a feeling this is going to work out really well.
Rules on making spare parts fyi DougHogg General Forum 0 02-04-2003 16:18
Weight Of Parts Mito Kit & Additional Hardware 3 13-03-2003 20:49
Q&A Discuss: parts as dead weight? CD47-Bot Extra Discussion 3 24-01-2003 12:30
Lots of Wheels and F = u x N archiver 2001 17 23-06-2002 23:37
weight and size of parts Greg Needel Kit & Additional Hardware 2 27-01-2002 23:25
