Go to Post The honor from any given job is not so much what you are doing, but how you do it; the hardest working garbage man deserves more honor then the laziest super hero. - Josh Hambright [more]
Unread 09-12-2011, 14:13
Michael_Pascua
Posts: n/a
pic: Team 1983 Fall CAD Project
Unread 09-12-2011, 14:14
Jamie Kalb Jamie Kalb is offline
Jamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to all
Re: pic: Team 1983 Fall CAD Project
I've been out of this competition a little too long to really comment on the overall design (although it looks very solid). Two quick things, though:
1.) I like the built-in follower wheels. Just so you know, VEX nows sells "dualie" omni wheels in that size, too: http://www.vexrobotics.com/products/.../276-1902.html
2.) Any particular reason the drive motors are up so high?
Keep up the good work!
Team 3129 Green MacHHHHine Founder, Captain (2009-10), Alumnus, and Mentor (2011-14)
2011-13 VEX World Championship...
Unread 09-12-2011, 14:16
It keeps the gearbox footprint out of the bellypan. Might be easier to work with things on there, but could also interfere with maintenance on the drive wheel below the gearbox.
Definitely looks solid though, what are the specs? Why the odd perimeter/flange on the edges?
Unread 09-12-2011, 14:35
AllenGregoryIV's Avatar
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Very nice design.
1. What pneumatic solenoids are you using? They look different than any I have seen but it might just be the angle.
2. How are the wheel shafts mounted to the frame? It looks like a 1/4-20 bolt.
Unread 09-12-2011, 15:12
Hmmm... sounds like one of those "engineering tradeoff" things! I'm just wondering about the effect on the COG.
Also, the easy-to-access main breaker is major plus.
Unread 09-12-2011, 15:42
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
The follower wheels are nice, but you could probably have mounted it upside-down so there's a little less metal under the belly and give yourself a little more clearance.
I always think that if you're going to build a robot in CAD you should at least figure out the correct center distance for a chain run, so I'm not a huge fan of tensioners. Just remember that the sliding one will probably slide, and often inopportunely.
Those are my only qualms, and it's really just an opinion thing anyway. Otherwise, it looks pretty solid and well thought-out. Very nicely done!
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 09-12-2011, 15:54
Justin Montois's Avatar
Justin Montois Justin Montois is offline
FirstUpdatesNow.com
FRC #3015 (Ranger Robotics)
Justin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond reputeJustin Montois has a reputation beyond repute
Send a message via AIM to Justin Montois
Looks awesome. Great Job.
@jmontois340
Team 3015
2016- World Championship Finalists and Tesla Division Champions with 2056, 1690 and 1405
2016- Greater Pittsburgh Regional Chairman's Award
2016- Pittsburgh Regional Finalists with 1023 and 4050
2015- Newton Division Finalists With 195 and 1756
2015- Finger Lakes Regional Champions with 4039 and 378
Unread 10-12-2011, 10:52
Chris is me's Avatar
AKA: Pinecone
You'll definitely want to spring load those follower wheels for accurate tracking. Other than that, looks like you've put quite a lot of thought into this design!
Unread 10-12-2011, 11:43
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
Sorry i'm asking this but what is the point of Follower wheels. What do the improve and how? I've never seen them before so i'm just wondering
I just finished my 7th Chassis in CAD (this year), im gonna put up the one that we are currently building for a prototype and the one I like the most in a different thread soon.
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 10-12-2011, 12:13
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
A follower wheel can have an encoder type of device connected to it to track distance traveled. Since it only rotates if the robot is actually moving, any wheel slip does not corrupt the distance measurement.
These were valuable in a game like the Rigolith game, where there was significant wheel spinning.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 10-12-2011, 12:18
Ninja_Bait's Avatar
AKA: Jake Potter
I imagine it is also very useful for mecanum, where it can be hard to predict exactly how the robot will move based on encoder values coming directly from the wheels, especially when strafing at odd angles.
Unread 10-12-2011, 14:08
O'Sancheski O'Sancheski is offline
O'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond repute
Are those 4in AM Plaction wheels you are using or custom?
If they are the Plactions, did you make them or download them? Because I cannot find where to download. If someone can tell me where they are located I would be very appreciative.
Unread 10-12-2011, 15:07
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
http://www.andymark.com/product-p/am-0198.htm
Click the 'Files and Documents tab'.
-Dustin Benedict
Unread 10-12-2011, 15:38
Thanks,
For some reason that tab wasn't loading on my computer. (Tried on another and works.)
Unread 10-12-2011, 17:14
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
The CAD looks nice, the only comment I have is that you seemed to have placed a lot of mass near the outside of the frame (motors and battery). Having that inertia out there will slow down your robot's turning speed. Maybe it's a problem, maybe it's not, just something to keep in mind.
