Go to Post Great CAD ** work! ** Cardboard Aided Design - philso [more]
Unread 10-12-2011, 15:59
tap13 tap13 is offline
AKA: PatrickA
FRC #3481 (Bronc Botz)
tap13 is an unknown quantity at this point
Ardruino and cRio
I want to know if Arduino directly connect to cRio or it has to go to digital sidecar before the cRio. Thanks!
Unread 10-12-2011, 16:55
404'd's Avatar
404'd 404'd is offline
Lead contributor of sweg
AKA: Josh
FRC #0967 (Iron Lions (9-sits-7))
404'd is a name known to all404'd is a name known to all404'd is a name known to all404'd is a name known to all404'd is a name known to all404'd is a name known to all
Re: Ardruino and cRio
How are you trying to use your arduino, to control motors and outputs? Because then it wouldn't be practical to use the c-rio in conjunction with an arduino, you can use the arduino directly as a replacement for the c-rio.
Driving "Career":
2012 GKC: Quarterfinals w/ 6th seeded alliance | Wisconsin: Quarterfinals - 3rd seeded alliance captains
2013 GKC: Quarterfinals w/ 5th seeded alliance | North Star: Regional winners, 2nd seeded alliance captains
2013 CMP: Curie Semis w/ 2056 + 3990
Unread 10-12-2011, 16:58
AKA: PatrickA
yeah for motor and outputs, well basically we're just researching for it.
Unread 10-12-2011, 17:12
In the offseason, yes, that would work.
In the competition season, at least in the past, that has been prohibited. In 2011, the rule was <R57>. In short, signals controlling motors had to come from the Digital Sidecar on the cRIO--no other sources were allowed.
Unread 10-12-2011, 17:17
AKA: PatrickA
thanks, I didn't even know, just new here
Unread 10-12-2011, 17:25
RoboMaster's Avatar
RoboMaster RoboMaster is offline
Alum, former programmer&co-captain
FRC #2472 (The Centurions)
RoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant future
You can use an Arduino for other, non prohibited things if you want though. FIRST gives us a lot of free reign for "custom circuits and sensors." So if there's something you know how to do on Arduino but can't find out how to do it on the FIRST control system, you could have the Arduino do the work and the cRIO would just receive or send commands. I guess you could hook Digital I/O pins together and have the cRIO and Arduino send and listen for dedicated On/Off signals along one or more pairs of pins.
Cons are that you can't use the Arduino to control motors, as mentioned, and that having two systems could easily be more complicated than just using the main FIRST control system. It would depend a lot on what you wanted to do with the Arduino.
I've always wanted to use a custom circuit though; it would be pretty cool.
My engineering blog: noeticbrainwaves.blogspot.com
I'm not slacking, my code's compiling
...and I'm using LabVIEW
Unread 10-12-2011, 17:28
Yep, RoboMaster has it right. As long as you aren't directly controlling motors with the Arduino, or doing something else that's prohibited by the rules, knock yourself out. Also, during the offseason, play with what you want to controls-wise.
Unread 10-12-2011, 17:52
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
If I were to connect an Arduino to a cRio, I would do it via the Serial port. This requires an RS232 level shifter (to 5v TTL logic of the Arduino), but is probably the easiest way on both ends.
Kettering Motorsports
Unread 10-12-2011, 21:52
RoboMaster's Avatar
But in normal competition setup you can't use the serial port. It only sends out basic status information about the cRIO. You would have to change some default stuff, which I think would be easier said than done, and then revert for competitions. Plus, the recent cRIOs don't even have a serial port, right? (I might be wrong on that).
Unread 10-12-2011, 21:59
apalrd's Avatar
More Torque!
VRC #3333
All false.
The serial port is a valid port (on both cRio's), there were no 2011 rules prohibiting its use.
It's available in code as a standard VISA serial port with WPI wrapper in LabVIEW. I would assume it's available in other languages similarly.
You would have to flip the Console Out DIP switch, but that's not very hard to do.
Unread 10-12-2011, 22:04
RoboMaster's Avatar
Huh, wow, thanks then for correcting me. Maybe it wasn't available in previous years, maybe 2009 when the system first came out or something.
This might be helpful, I don't know if you can run these VIs on the cRIO.
http://web.me.com/iklln6/automation/LabVIEW.html
Unread 10-12-2011, 23:10
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
We used an Arduino in 2011 to read encoders and the transmit distance travelled during auton.
The Arduino directly read the encoders and talked to the cRIO via serial.
This worked great. We'll be doing another Aruino project in 2012.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 11-12-2011, 00:21
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Our team was recently trying to get the Arduino to work on the cRIO.
Is there anything special we need to do?
I just read above we needed to flip the DIP switch?
Our programmer (JAVA) was working on this and was getting unexpected errors.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 11-12-2011, 02:08
AKA: PatrickA
just to be sure... so is there any limit/prohibitions on what we can use on the arduino?
Spoiler for :
Thanks all for the replies
Unread 11-12-2011, 03:39
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
Spoiler for :
Can you be more specific? Do you mean, what you can add on to the board for more features like other wireless, or what you can attach and control/sense?
Attending: MN Duluth Regional
