Go to Post You can never be done too early for more testing and practice! - Donut [more]
Unread 11-12-2011, 14:54
FRC #1836 (MilkenKnights)
Sprocket Tensioning
I've heard that for #35 chain, if you space the sprockets 3/4 in away from each other, you do not need tensioners? Is this true, and if so, where is the measurement taken from? Furthermore, do most teams prefer using this method, or machining bearing blocks? Thanks in advance.
