Originally Posted by MICHAELABICK
Thanks, and sorry for the inaccuracies in my question. I meant that I've heard that for #35 chain, sprockets can be spaced in multiples of 3/4. I'm guessing this is correct. Also, would teams still recommend using a bearing block, so that you can account for chain stretching.
This is only true when the sprockets are the same size, and it's actually pitch multiples, so the multiple should be 3/8".
That gives you an integer number of links. (3/4" will work because it is a multiple of 3/8".)
http://www.rbracing-rsr.com/chainlength.html is a very simple calculator. Set the pitch to .375 and try different combinations of sprocket size and different lengths. You'll see that for a 1:1 sprocket ratio it's easy to get integer numbers of links (just put a multiple of .375 for your center distance). For any other ratio, you'll have to use a bit of finagling to get it a center distance that yields an integer number of links.
