Go to Post Friends don't let friends drive mecanum. Enough said... - Botsup [more]
Unread 13-12-2011, 12:08
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
pic: 816's 2011 Off-Season Teaser
Unread 13-12-2011, 12:09
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
Re: pic: 816's 2011 Off-Season Teaser
Are they gripper parts? It looks like a pulley with a hex broach and something else with a hex broach
Unread 13-12-2011, 12:17
Joining the 900 Meme Team
FRC #0079
That's no pulley! (I cannot confirm or deny that I am watching star wars)
I assume I'm ineligible for this...
Unread 13-12-2011, 12:31
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
A little hint to stir the crowd;
It does cool stuff.
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
Unread 13-12-2011, 12:53
sithmonkey13's Avatar
sithmonkey13 sithmonkey13 is offline
AKA: Nathan
FRC #1178 (DURT)
sithmonkey13 is a name known to allsithmonkey13 is a name known to allsithmonkey13 is a name known to allsithmonkey13 is a name known to allsithmonkey13 is a name known to allsithmonkey13 is a name known to all
Originally Posted by Nick Lawrence View Post
It does cool stuff.
-Nick
Isn't anything robotics related cool?
Note: You cannot tell the difference between "OK Go" and "OK No" when there 2 walls between you and the robot. At that point, the only thing between injury and safety for the mechanical guys is their ninja skills.
Unread 13-12-2011, 13:07
AdamHeard's Avatar
Lead Mentor
A double sprocket before the teeth are hobbed, and the cylinder is likely a wheel hub to be press/cast into a plastic wheel.
Unread 13-12-2011, 13:25
FRC #0079
No, it is a system for keeping the Fro fluffy.
Unread 13-12-2011, 13:28
thefro526's Avatar
Mentor for Hire.
Dang it.
You're right, though I hoped that it'd take a little longer to figure out.
The part on the left is a blank for a 22T double sprocket, made from 7075 Aluminum. It's been broached before the sprocket cutting to make things a little easier for the mill operator.
The part on the right is a 'plug' for a 2" wide colson wheel, made from 6061 AL. Preliminary testing shows that the press is good to at least 80 foot-pounds of torque.
(I'll have to bug you on FB for a shipping address once the stickers are made.)
-Dustin Benedict
Unread 13-12-2011, 13:29
CNettles11's Avatar
CNettles11 CNettles11 is offline
AKA: Chris Nettles
FRC #3502 (Octo-Pi-Rates)
CNettles11 is a jewel in the roughCNettles11 is a jewel in the roughCNettles11 is a jewel in the roughCNettles11 is a jewel in the rough
I'm pretty sure that the smaller item could be part of a cable winch. Could the larger item be an adapter from a hex shaft to a different type of shaft?
EDIT: Dangit, I was both late and wrong.
Unread 13-12-2011, 14:15
rcmolloy's Avatar
rcmolloy rcmolloy is offline
Remote Mentor
AKA: Robert Cory Molloy
rcmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond repute
Oh I see where you're going with this one Dustin. The topic that we were discussing about makes sense then.
...Or just give them to me for hand delivery dude. We don't live that far away.
FRC 1647: Iron Devils - 2009 - 2011
FRC 973: Greybots - 2011 - 20XX
"While I was a student in FIRST, it was all about becoming inspired. Now as a mentor/engineering student, it's all about making sure learn everything I can so I can carry that on inspiration for future generations while having a hell of a lot of fun!"
Unread 13-12-2011, 14:23
FRC #0079
If you guys can wait until Madera I can hand deliver them as long as they go next to the "Powered by..." sticker on your bot
Unread 13-12-2011, 14:27
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
Drain plug to keep the water out and a small anchor???
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 13-12-2011, 14:35
Brandon Holley's Avatar
I've been making a variation of the press-fit Colson hub since 05 using the same principle. If I'm seeing the hub correctly, it looks like its knurled which is something I've had great success with as well.
Looking good.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 13-12-2011, 14:42
AdamHeard's Avatar
Lead Mentor
For season I see the resources used to make the double sprockets better used elsewhere, and instead just purchase off the shelf sprockets.
Unread 13-12-2011, 15:35
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Why do I get the feeling there is going to be a heck of a good time had at Madera?
The views expressed are mine and should not be construed to represent the views of anyone else.
