Go to Post Don't give FIRST ideas...we like our 45 day build season. They can make it shorter. Never underestimate the power of the GDC. - Littleboy [more]
Unread 13-12-2011, 19:23
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: pic: 816's 2011 Off-Season Teaser
Originally Posted by craigboez View Post
I assume your hex broach goes all the way thru the ~2" wide Colson hub. Did you have any issues hex broaching that length? The Dumont literature states the max length of cut is 1-3/8" but that is based on mild steel. I'm curious what it can do in aluminum.
I can tell you from our experience that would likely be a problem and require it to be broached multiple times, or from both sides (with a standard push broach). It's going to take a LOT of force too, since you have so much tooth engagement.
2001-2004: Team 100
2006-Present: Team 254
Unread 14-12-2011, 08:54
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
As far as I can tell, the Colson hex may need to be cleaned up a bit. It seems to need to be opened up by a few thousandths, or we might just undersize our shafts a bit. The press we used was massive, I can get the tonnage if anyone wants it. Didn't seem like it took too much force compared to the depth of the broach.
-Dustin Benedict
Unread 05-01-2012, 14:56
thefro526's Avatar
Mentor for Hire.
Just wanted to Follow up on Cory's post in case someone stumbles onto this thread in the future.
Each part, especially the hubs, did need to be broached multiple times. We've found that most Aluminum Hex runs a few thousandths over, which was enough to make assembly a PITA. If I counted correctly, each sprocket has now had the broach pressed through it three times, once to do the primary cut, two more (each from a different side) to open the hex up enough that it plays well with hex shaft. The wheels each took between 3 and 4 passes a piece before they played nice, again alternating sides with each pass.
With any luck, this should be running tonight.
-Dustin Benedict
Unread 05-01-2012, 15:16
Brandon Holley's Avatar
Come back with vids.
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
