Go to Post Remember that starting a team is ALOT of work, but it’s a lot of fun once it gets going. Its all about the students, so don’t get too carried away ;) - Travis Covington [more]
Unread 13-12-2011, 21:15
h3x h3x is offline
h3x is an unknown quantity at this point
[FTC]: Robot size question
We are wondering if we can have zip ties sticking off of our robot that makes it a little bit more than 18". In the rulebook, it says that the robot must fit in an 18"x18"x18" box and not exert a force on the sides of the box. But does that mean a significant force, or any force at all (like the zip ties)?
Thanks!
Unread 13-12-2011, 22:45
normalmutant's Avatar
normalmutant normalmutant is offline
AKA: Nathan
FTC #3539 (Say Watt?)
normalmutant has a spectacular aura aboutnormalmutant has a spectacular aura about
Re: [FTC]: Robot size question
I'm fairly certain it means zip ties too. Is this for a sweeper? In our first year, in order to fit, we made our sweeper have zip ties extend in only two directions from the axle, so that if the axle was turned so the the zip ties were vertical, it would fit.
SAY-WATT.ORG
Unread 13-12-2011, 22:49
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Agreed. Plus, since zip ties can exert a force strong enough to move balls, the force can't really be called insignificant.
Unread 13-12-2011, 23:13
Michael Coleman's Avatar
Michael Coleman Michael Coleman is offline
Michael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of lightMichael Coleman is a glorious beacon of light
This question is addressed in the FTC Q&A forum. See post #7 in this thread:
ftcforum.usfirst.org/showthread.php?362-Robot-Inspection-Answers
Unread 14-12-2011, 00:25
h3x h3x is offline
Great, thanks.
We have a conveyor belt with zip ties, and I guess we could take off some of them but we don't want balls slipping, because sometimes they sneak through a few zip ties.
Unread 14-12-2011, 07:22
If you position the belt so that the ties are within the starting size then you are OK. You must insure that you are positioned that way at the start of each match. Your LRI and Head Ref communicate throughout the event.
