Go to Post there's no time like week 5 to learn programming :D - dcarr [more]
Unread 14-12-2011, 09:20
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: pic: 816's 2011 Off-Season Teaser
Originally Posted by Brandon Holley View Post
Ah- yes the mental picture popped into place. Knurling is really REALLY simple (and pretty cool). It could be something you guys experiment with now, especially since you already have the lathe, etc.
The gearbox plate looks good. I assume bearings will be pressed into it. I'd be curious to see what results you get as far as the tolerance on the press fit from a waterjet. We've had access to a waterjet for a while, and we use it for a lot of things. One thing I've always been wary about is bearing holes though. We usually will cut out almost the entire part and then go back to correct the bearing holes with a secondary process.
-Brando
We might experiment with knurling in house before build, but we have about a dozen other parts that are on the priority list first. Our sponsor can knurl if we absolutely needed it too.
The bearings are more of a tight slip fit then a true press. I can get a good measure on the bore when I go to the shop tonight. We have originally intended to ream the holes under the assumption that they'd run under, but they came out of the waterjet just right it seems.
Got one of the finished Sprockets:
-Dustin Benedict
