Go to Post GP is a much longer-term investment, yet offers surprisingly high returns. Just like 401(k) plans, the important thing is to keep making contributions even when it seems there's no reward for it. - ayeckley [more]
Unread 14-12-2011, 07:37
nick_sheets nick_sheets is offline
FRC #3569
Team Role: CAD
nick_sheets will become famous soon enoughnick_sheets will become famous soon enough
Press Fit
Hi guys
Our team is currently working with our sponsor and we were wondering what size our bearing holes should be for a fr6 and fr8 bearing press fit? Should we do a .874 - .873?
Also if we anodize, our shop said its a .001 penetration and a .001 surface finish. Should be go to a .875 - .874 hole? our teacher and I don't really know how to do this.
Thank you very much
Unread 14-12-2011, 08:14
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Re: Press Fit
0.873 inch is way too tight. 0.874 inch is still tight. 0.8748 is just right.
AndyMark shows bearing pocket dimensions in their plastic wheels 0.001 inch smaller than nominal bearing O.D. In those wheels the plastic gives a little when you press in the steel bearing. Aluminum will give also, but not as much.
Good practice for pressing bearings of this O.D. range into metal pockets is 0.001 mm to 0.010 mm smaller than nominal bearing O.D. -- that would be 0.00004 to 0.0004 inch. That tolerance is very difficult to control using the tools of most FRC teams.
Richard Wallace
since 2003
Unread 14-12-2011, 08:24
Gdeaver Gdeaver is offline
FRC #1640
Re: Press Fit
If tolerances can not be held, A bearing spacer can help solve the problem. Search Mcmaster-Carr for bearing spacer to see what they look like.
Unread 14-12-2011, 08:46
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Re: Press Fit
Because my team's equipment was not more accurate, I always went 0.001" under and put a generous chamfer on the hole to help in pressing the bearing in.
You could also aim for a close fit and glue the bearings in or peen them in. I've had good luck peening in flanged bearings.
Unread 14-12-2011, 08:52
Jared Russell's Avatar
Taking a year (mostly) off
Re: Press Fit
If you use flanged bearings and then trap them with spacers/collars/nuts/snap rings, you can get away with a pretty sloppy slip fit.
Unread 14-12-2011, 09:57
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Press Fit
Even on a drive train with #25 chain?
GitHub
Unread 14-12-2011, 10:17
Brandon Holley's Avatar
Re: Press Fit
We have been anodizing our robots for the past 6 years. There are two ways to deal with the press fit bearing holes.
1. Mask them, and use your machined (and hopefully tightly toleranced) hole for your press fit.
2. Use them to your advantage and try to create a press fit using the anodize.
I highly recommend going with method #1. We have had to clear away anodizing inside a bearing hole many times because the press fit ended up being too tight. Year to year, batch to batch, we just couldn't get a consistent enough thickness on the anodize where we were comfortable using it as THE press fit.
Just my opinion based on our experiences in the world of anodizing.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 14-12-2011, 10:28
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Press Fit
A standard Type II color anodize should not add any more than about 0.0004 inches. A hard anodize certainly would. I second the recommendation to capture the bearings, and size them for a close slip fit. Pressing them is nice simply so they don't fall out during maintenance but it's difficult to get the perfect fit. You're looking for in the neighborhood of 0.0003 smaller.
Unless you have a high-end shop doing the work to your tolerances and inspecting it, be sure to give them an actual bearing they can reference to check as they're machining the parts.
Unread 14-12-2011, 10:39
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: Press Fit
Yup.
For the last three seasons, all the sheet metal parts on 228's robots have never had actual press fit bearing holes, simply because that would cause our sponsor to have to swap out a standard size die (0.875") for the less common press fit size in the turret punch.
We've dealt with this two ways: 1) use flanged bearings, stepped shafts and Delrin spacers to keep everything captured, and 2) put some Loctite around the outside of the bearing when inserting it the first time.
For a FRC robot that will literally only see tens of hours of operation, this works just fine.
Art Dutra IV
世上无难事,只怕有心人.
Unread 14-12-2011, 10:53
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Re: Press Fit
Originally Posted by artdutra04 View Post
Yup.
Something like Loctite Press Fit Repair 660 works great in this sort of application.
Unread 14-12-2011, 11:36
JesseK's Avatar
FRC #1885 (ILITE)
Re: Press Fit
Thanks for the tip Arthur.
GitHub
Unread 14-12-2011, 11:45
artdutra04's Avatar
Re: Press Fit
We just used the same Loctite 248 we use for everything else.
// Which is also a great tip for all robotics teams: ditch your liquid Loctite and switch to Loctite 248. This is available in a "QuickStix" form (it's basically a glue-stick) and is more or less impossible to spill or drip on things. Before 228 switched to this, our students used to constantly spill and waste Loctite. Now, one tube seems to last forever.
Art Dutra IV
世上无难事,只怕有心人.
Unread 14-12-2011, 13:25
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Press Fit
We make most of our press fits for bearings .0005-.0002 undersize. Even attempting this without a CNC machine is a waste of time, IMO. You're better off just reaming it to the nominal size and using some of the green wicking loctite to retain the bearing. It's as good as a press (and absolutely will not let go, without extreme heat).
2001-2004: Team 100
2006-Present: Team 254
Unread 14-12-2011, 14:15
JesseK's Avatar
FRC #1885 (ILITE)
Re: Press Fit
Side topic -- somewhat related I suppose --
For a 1-1/8" (or 1-1/16") Silver & Demming bit that would cut into 1/4" Polycarb and/or 1/4" Aluminum ...
... would we want to get a carbide-tipped bit or would a HSS bit suffice? This assumes that S&D bits can do the 1-1/8" hole without too much slop, which also assumes we would do starter holes with a smaller drill bit first. It would also be done on a mill we've been able to get within 1/64" after nominal practice.
GitHub
Unread 14-12-2011, 14:41
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Re: Press Fit
HSS would definitely suffice, though I prefer to get coated and/or carbide tooling because it is so much more durable. To quote the machinist I worked with at my college: "it costs twice as much, but lasts five times longer."
My opinion is that for 1/4" and thinner you'd be better off with a good quality step drill, hole cutter, and/or reamer, depending on what sort of fit you wanted. I don't like how big drill bits like that are not very forgiving. They can make 'triangle holes' and catch big burrs and spin parts when they're used in thin material.
