Go to Post its not that I cant spell, I'm just being international. . . . I like it - Stuart [more]
Unread 15-12-2011, 00:46
runfrodorun runfrodorun is offline
FRC #0111
runfrodorun is an unknown quantity at this point
2010 cRIO Image
I'm looking for the latest update for the 2010 cRIO Image...does anybody know where I might find one? (Navigating the vast jungles of ni.com did not help very much)
Unread 15-12-2011, 01:01
FRC #0111
Re: 2010 cRIO Image
Ok, I think nevermind. I looked around, and It seems that the imaging tool will have an option for 2010 image? I don't have a c-rio with me right now so I can't run the tool to be sure because it won't stay open if you don't have a crio on the network. I was just trying to be prepared for tomorrow.
Unread 15-12-2011, 02:19
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
Re: 2010 cRIO Image
What's significant about tomorrow? And what does that have to do with an almost 2 year old image? What are you trying to do?
Unread 15-12-2011, 03:47
Cecil's Avatar
Cecil Cecil is offline
AKA: Alex Hummel
FRC #2010 (Lightning Bots)
Cecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to beholdCecil is a splendid one to behold
Re: 2010 cRIO Image
Well.. I would guess that their team meeting is tomorrow. That, and perhaps they would like to resurrect an old robot for demonstration purposes. I know we have at least 2 robots around the shop with everything but a brain in them because we can't afford another cRIO. According to the FRC Robot Inspection Checklist for 2010, you need v20 of the image. Everything for that year can be found here.
If you can use an updated image for older code, then this is news to me, and will stop flashing this controller every time it goes in an old robot...
I'm right 90% of the time, so why worry about the other 3%?
Unread 15-12-2011, 06:33
Re: 2010 cRIO Image
If you're just downloading an old build, then you'll need the matching vintage of the cRIO image.
You can use the newest image if you still have your original code and can just re-build your code under the latest LabVIEW version.
There might be minor updates to your code that you have to make as options and libraries may change in later LV versions, but usually you simply have to re-build your old code to drag in the cRIO image matching libraries.
Unread 15-12-2011, 11:01
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
Re: 2010 cRIO Image
As Mark said, if you are simply trying to run your 2010 code, and you have the project files, try building it with the 2011 platform first. Our 2010 code runs just fine on the 2011 image.
Unread 15-12-2011, 11:42
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
Re: 2010 cRIO Image
same here- i've run 2010 and 2009 code using 2011 labview and the 2011 image without issues...
Unread 15-12-2011, 12:10
Omar's Avatar
Omar Omar is offline
Omar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of lightOmar is a glorious beacon of light
Re: 2010 cRIO Image
Let me make sure. You are running LabVIEW version 8.6 with the image from last year's 2011 image and not running "LabVIEW version 2011"?
It's my understanding the FRC cRIO 2011 image is not compatable with LabVIEW 2011.
I can see how the new version labling of LabVIEW is going to cause confusion.
It's like my updates DVD I get twice a year from NI. The set I received back in Feb was labled "Developer Suite 2011" but contain LabVIEW 2010.
Omar
Unread 15-12-2011, 13:56
Re: 2010 cRIO Image
That is correct. FRC 2010 and FRC 2011 are based on LabVIEW 8.6. FRC 2012 will be based on LabVIEW 2011.
-Joe
Unread 15-12-2011, 22:45
Cecil's Avatar
AKA: Alex Hummel
Re: 2010 cRIO Image
So… I can actually get rid on LabView 8.5 from my laptop? And 2009's program will compile with LabView 8.6.1? I don't mean to hijack here, but I guess I've never really tried to open it in 8.6.1. It's always just opened 8.5.
Unread 16-12-2011, 00:24
ratdude747's Avatar
AKA: Larry Bolan
Re: 2010 cRIO Image
i should have been more clear.
it was 8.6. 2011 FRC updates. sorry about that.
