Go to Post Dang! And here I was getting all excited about finding out about the game!!! - dlavery [more]
Unread 15-12-2011, 02:10
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Looking for a pulley
I'm looking for a 2-sheave step pulley for a B series V-belt. It needs a 7/8" bore with a 3/16" keyway. I'm coming up empty handed at all the traditional suppliers. I'd even settle for a 3-step pulley. Size needs to be rather small. The pitch diameter of the smaller sheave should be around 1.5 inches or so. Any ideas of where to look?
Unread 15-12-2011, 19:07
avanboekel's Avatar
avanboekel avanboekel is offline
AKA: Adam Van Boekel
FRC #5934 (Gear it Forward, Crowbotics)
avanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant future
Re: Looking for a pulley
Have you looked on McMaster-Carr yet? I believe this is where we purchased our pulleys for last year's bot.
2338 Gear It Forward | Student 2010-2013 | Mentor 2014-Present | oswegofirst.org
2013 Wisconsin Regional Winner (1732, 111, 2338)
2013 Midwest Regional Dean's List Finalist
2015 Midwest Regional Chairman's Award Winner
2015 Archimedes Subdivision Winner (1023, 2338, 3996, 1089)
2016 Midwest Regional Chairman's Award Winner
4096 CTRL-Z | Mentor 2014 | team4096.org
5934 Crowbotics | Mentor 2016-Present | crowbotics.org
Unread 15-12-2011, 19:10
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
Try SDP-SI, too. Also be prepared to bore and broach the pulley yourself, because you may not be able to get exactly the right dimensions.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
Unread 15-12-2011, 19:46
DonRotolo's Avatar
Back to humble
FRC #0832
Grainger has several, but 3- and 4-step, all 5/8 bore, more or less same as McMaster.
I work on old lathes, and one trick for unobtanium multi-sheave pulleys is to get what you need as single pulleys (which are plentiful in whatever size you need) and just mount them all on the same shaft, trimming the hub(s) if necessary. Push comes to shove, you can even pin them together if necessary.
Unread 15-12-2011, 21:07
As mentioned in the first post, I checked all the traditional sources already. Also, I was looking for a totally stock solution, with no boring or broaching needed.
I'll be honest, that never actually crossed my mind. Too many things on the brain I guess. I may do just that. It's for a milling machine.
