Go to Post Well our closest regional is a Hawaii, it's a bit hard for us to drive 8000km (5000 miles) across the pacific... - timytamy [more]
Unread 16-12-2011, 17:36
baronep's Avatar
baronep baronep is offline
Student President
FRC #2848 (Jesuit All-Sparks)
baronep is on a distinguished road
Sheet Metal Brake
Our team is looking to buy a sheet metal brake and we have a budget of around $500. We would be looking to bend stuff .125" and less. Does anyone have a suggestion? A box break would be convenient but not critical.
Unread 16-12-2011, 17:49
Re: Sheet Metal Brake
What size parts are you looking to bend?
24" wide is decently common.
Unread 16-12-2011, 19:11
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
Red face Re: Sheet Metal Brake
Is this what you're looking for? http://www.amazon.com/SHOP-FOX-M1011.../dp/B001R23S7W
(that one is kind of small, but it fits in your budget and I'm not sure exactly what size you are looking for). For under $500, you're probably not going to be able to get a decent width (24") and you probably won't be able to bend up to .125" (I assume you're looking to bend aluminum, but I'm not sure).
My old team bought this one (http://www.amazon.com/M1042-24-Inch-...d_sim_sbs_hi_1) last year, but it's a little bit out of your budget (definitely worth the extra money though), it's worked very well so far.
Unread 17-12-2011, 01:34
autox_vette autox_vette is offline
FRC #2451 (PWNAGE)
autox_vette is on a distinguished road
Since most of these brakes are rated for what gauge mild steel they can bend, is there any rule of thumb how to compare capacity of mild steel to capacity of Al?
Unread 17-12-2011, 08:57
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
I have one of these: http://www.harborfreight.com/garage-...roll-5907.html
Nice because it can cut/shear thin stock also. Used it last year to build our minibot.
Just tried some 1/8" scraps. It will easily bend strips up to 2" wide, beyond that it gets hard, and will not shear 1/8" aluminum.
Unread 17-12-2011, 10:29
Dick Linn's Avatar
no team (Synergy)
Pay particular attention to the rated capacity of a bending brake. It's too easy to convert one to a "break".
Many people make their own, especially for smaller widths but heavier steel or Aluminum stock. If you go to www.hobartwelders.com and in the advanced forum search, search for METAL BRAKE and the user name DAN. That should give you links to the 14 different posts Dan made for the bender.
If you do a Google search for "dan bender site:hobartwelders.com" you will find more discussion and some other versions by various folks. I think this is the same bender, with the plans at post # 29. (Rocky D is still around, if you needed Autocad plans.)
http://www.millerwelds.com/resources...&p=157#post157
There are plans for one type from a link here, though I have no experience with this particular one:
http://www.homemetalshopclub.org/projects/project.html
http://www.homemetalshopclub.org/pro...etal_brake.zip
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 17-12-2011, 11:43
DonRotolo's Avatar
Back to humble
FRC #0832
Check the used market as well. A big brake (that will comfortably bend 1/8 aluminum) will be expensive new. Otherwise you'll take a smaller brake and push it beyond its capacity, never a good thing.
Look into getting a hydraulic press and a bending die to make Press Brake (see this illustration for the principle). The die can be home-made from large steel angle that's been machined.
Think about how a brake is made and then consider building one yourself (like a bigger one of these). I mean, if you can build a robot, you can build a brake. Materials will cost $2-300.
Unread 18-12-2011, 00:03
cire's Avatar
cire cire is offline
Alumni, Mentor, and Coach
AKA: Eric Diehr
FRC #1716 (Redbird Robotics)
cire is just really nicecire is just really nicecire is just really nicecire is just really nice
Send a message via MSN to cire
I own that very brake (with a different brand sticker on it) - you wont be able to bend 1/8" with that brake, 0.080" is the absolute max you can bend on it really, I'd recommend sticking to 0.063" or less with it though (5052 AL).
