Go to Post Sometimes, you just have to beat something (someone?) into submission. Yes, you can use your head, but its a lot easier with a hammer. - Andy A. [more]
Unread 16-12-2011, 15:17
linuxboy linuxboy is offline
AKA: Oliver Graff
FRC #3780
linuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud oflinuxboy has much to be proud of
Release - FRC Network Monitor
Hi all,
Last night I wrote a quick little network monitor in Java for FRC. The design isn't great, but it just indicates whether or not certain devices are connected to the network. This does not change IP settings, those must be properly set up on the same subnet as those devices, or, have a route to them.
Oliver
Unread 16-12-2011, 18:12
RoboMaster's Avatar
RoboMaster RoboMaster is offline
Alum, former programmer&co-captain
FRC #2472 (The Centurions)
RoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant future
Re: Release - FRC Network Monitor
Great idea, but it didn't work for me. I tried to run it and it gave me an error that a main file was missing. See picture, hope that helps.
My engineering blog: noeticbrainwaves.blogspot.com
I'm not slacking, my code's compiling
...and I'm using LabVIEW
Unread 16-12-2011, 18:34
AKA: Oliver Graff
FRC #3780
Interesting, try running it from the command line by navigating to the folder its in and running java -jar FRCNetworkMonitor.jar
I'll see if I can recreate the behavior as well.
Oliver
Unread 17-12-2011, 00:02
AKA: Oliver Graff
FRC #3780
I compiled it on windows, hopefully that will help. The updated version is in the first post.
Let me know if it works.
Oliver
Unread 17-12-2011, 00:13
RoboMaster's Avatar
Nope, the updated version gives the same results.
This is on Windows 7 64bit, so maybe that changes things...
Unread 17-12-2011, 01:11
AKA: Oliver Graff
FRC #3780
Okay, that should fix it. Netbeans does some weird stuff when it compiles, and it does not include some of the supporting classes in the main .jar
To fix it I just zipped up the entire "dist" folder. You should be able to unzip that, and double click the .jar file, and have it run.
Oliver
Unread 17-12-2011, 01:23
RoboMaster's Avatar
That did it. Looks great. I don't have the robot handy of course, but I'll be sure to try it out. Thanks!
Unread 21-12-2011, 16:45
jhersh jhersh is offline
National Instruments
AKA: Joe Hershberger
FRC #2468 (Appreciate)
You need to pull the jar file from the "dist/full" dir instead of from "dist". It contains all needed support libraries.
