Go to Post If you're not trying to make the best possible product given your set of constraints and resources I'm not quite sure what you're doing. - Aren_Hill [more]
  #46   Spotlight this post!
Unread 15-12-2011, 21:57
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Re: pic: Team 3647 West Coast Drive
Someone asked for a photo of the bearing block, here it is.
Two 500 Hex Bearings press fit into 1/4 alum plates.
Bolt holes are pocketed so it slides about .25inch to allow for tensioning.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
  #47   Spotlight this post!
Unread 15-12-2011, 23:02
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Originally Posted by Ninja_Bait View Post
I looked it up: Pop Rivets vs. Bolts
These are two kind of arbitrary sources, but it shows that while rivets are not quite as strong, they're comparable. The steel 1/4" rivet (shear: 2750 lbs.) beats Grade 2 1/4" bolts (shear:~2200 lbs.). However, the higher grades outmatch the rivets by a lot.
I assume they did a straight shear-strength calculation, which is good, but doesn't describe the whole situation.
Friction matters a lot, especially when clamping aluminum to aluminum. The static coefficient of friction is generally over 1, sometimes well over. You'd be looking at (to use my own numbers) 75%*1750lbf (proof load GR2 1/4-20) * 1.2 (coefficient of friction Al-Al) = 1575lb, so it would require 1575 lb of force to overcome the friction generated by the bolt's clamping force before the bolt sees a single pound of shear force, assuming the bolt was properly torqued.
Edit: I looked at the bearing strength of aluminum, assuming 6061 T6 it is 56ksi. Doing the math on an 1/4" diameter hole in an 1/8" thick plate says that anything over 1750lbf will start to yield the material around the fastener, so the excess strength of the rivet over a grade 2 bolt is meaningless because that will not be the mode of failure. The bolt's clamping force now makes it a clear winner.
  #48   Spotlight this post!
Unread 16-12-2011, 11:19
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
[/img]
Neat design. How do you keep the two plates aligned with each other and the shaft perpendicular to the frame?
  #49   Spotlight this post!
Unread 16-12-2011, 15:50
Mk.32's Avatar
AKA: Mark
With 2 bolts and a shaft going though the blocks, they will be aligned when the bolts are tightened. I have seen this type of design before and it seems to work pretty well.
  #50   Spotlight this post!
Unread 16-12-2011, 15:59
AdamHeard's Avatar
Lead Mentor
I've got my doubts about the two separate plates being able to adequately support the shaft. It would probably work, but it's going to put unnecessary excess load on the bearings and possibly deflect more.
The bearings shouldn't count on the shaft for alignment.
I know 254, 1538, 968 and our bearing blocks all are complete and rigid assemblies.
  #51   Spotlight this post!
Unread 16-12-2011, 16:38
Chris is me's Avatar
AKA: Pinecone
We take a weight penalty by doing this, but this is why we just drill through a 1/8" extrusion and mount our bearings in a stationary manner. Precision milling multiple solid parts like the Poofs do and making them concentric is harder for us with our resources, so maybe it would be easier to do that and add floating tensioners or idlers.
To make up for the inefficiency of not necessarily being able to get a perfect chain tension, we switched to belts. This line of thought ultimately led to how we decided to make our "west coast" (east coast?) drive.
  #52   Spotlight this post!
Unread 16-12-2011, 17:33
AdamHeard's Avatar
Lead Mentor
The assumption that the bearing blocks must be difficult to make is flawed. They can be dlne really simple and easy.
  #53   Spotlight this post!
Unread 16-12-2011, 18:10
Mr. Van Mr. Van is offline
#0599 (Robo-Dox)
Mr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond reputeMr. Van has a reputation beyond repute
If I recall, this bearing block assembly has been used by numerous teams (254, 4, 968, 1868, 60, and probably others) for many years - going back to perhaps 2004 or earlier. There must be complete drawings of the part available somewhere...
We have developed an alternative (which may be heavier, I don't know). In the past, we've taken two bearing plates and milled a grove in them above and below the bearing on the "inside". A top and bottom plate was bolted into this groove making a "box" that surrounds the chassis 1" x 2". This keeps everything square. We actually make this "oversized" to allow for adjusting the heights of the wheels as well as their fore/aft position.
- Mr. Van
Coach, Robodox
  #54   Spotlight this post!
Unread 16-12-2011, 19:32
Joining the 900 Meme Team
FRC #0079
The assumption that the bearing blocks must be difficult to make is flawed. They can be done really simple and easy.
How? < legit question
  #55   Spotlight this post!
Unread 17-12-2011, 00:12
Marc S.'s Avatar
Marc S. Marc S. is offline
Read the Manual! PLEASE!
AKA: Adversity
FRC #3925 (Robotics)
Marc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond reputeMarc S. has a reputation beyond repute
I don't want to sound like a smart @ss, but a bearing block is just that, a block. Add a 1.125" hole through the middle(for the bearings), a couple of threaded holes to hold it all together and you basically have a bearing block. We add a .125" chamfer to fit in the filleted slot, and make it .010" under the width of the frame tubing to make sure it clamps. Check out our cad and you'll see what i'm talking about. Our bearing blocks can be machined on a standard mill no problem.
This is also how 60, 254,968, 1538, and many other WCD's are setup.
Alumnus FRC 973: 2010, 2011, 2012, 2013
2011 World Championship Winning Alliance Member
FLL Mentor and Competition Judge 2012-2015
Student-Mentor FRC 5102: 2014, 2015
Student-Mentor FRC 3925: 2015, 2016
FRC Ventura Regional Planning Committee Member & Regional Field Supervisor: 2015, 2016
  #56   Spotlight this post!
Unread 17-12-2011, 00:41
Mk.32's Avatar
AKA: Mark
Newb question but hat does the block add over the plates I used?
Isn't the bearings taking all the weight either way?
  #57   Spotlight this post!
Unread 17-12-2011, 00:46
AdamHeard's Avatar
Lead Mentor
254, etc.... use a much different design that is similar in functionality, but different in execution.
Our blocks are pretty much a block with the bearing hole for both bearings. This makes each face plate effectively a large, special shaped washer.
  #58   Spotlight this post!
Unread 17-12-2011, 00:48
AdamHeard's Avatar
Lead Mentor
There isn't anything holding the bearings concentric and in plane with each other very well. This could cause the bearings to get loaded nonradially and become less efficient.
It also could be a negligable amount.
Check out one of our bases to see an example of our block, which is very simple to make.
  #59   Spotlight this post!
Unread 17-12-2011, 00:56
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Our experience has been that separate plates on either side of the rail on this type of drive do not work well. The tension in the chain tends to pull the axles at each end toward the center, creating toe on the wheels.
I'd argue that the bearing block design is the most important (and most overlooked) element in this sort of design. Plates alone probably won't cut it.
--Madison--
...down at the Ozdust!
  #60   Spotlight this post!
Unread 17-12-2011, 16:30
Mk.32's Avatar
AKA: Mark
Well taking the feed back from above, here is take 2.
Literally a bearing block. With a pocket cut into the rail that allows it to slide about .25inch for tensioning. And two 1/8 plates that hold it in place.
